Fuel Pump Issue - Defender Source
Old November 4th, 2004, 02:47 AM
bjenk
Brian Jenkinson
1994 D90
Fuel Pump Issue
I am new to the d-90 source, and happy to be here. I recently purchased a 94 d90. However, the bad news...The 90 will not start. It is turning over, but not starting. I believe it is a fuel pump problem. I have disconnected the fuel line at the filter and with ignition switch on there is no fuel pumping. I have checked the fuse, but have no idea where the relay is? I have included a picture of the fuse box. I have read up on the forum of similar problems. ANY HELP is appreciated...Also, where is the inertia switch?
Morrison CO
Old November 4th, 2004, 03:09 AM
The relays are metal, there are two.
If your pump is dead and you buy a new one I would like to buy your old one (long story . . .)
Ron
Old November 4th, 2004, 07:31 AM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
The 95's relays are under the passenger seat... Is that the same for the 94s? anyone? Brian, you should probably pickup a service manual (so should I!)
Old November 4th, 2004, 09:45 AM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
It's different on a '94. The fuel pump relay is on the passenger side, lower dash, behind a/c fascia (if you have a/c), just to the left of the ECM. It's a pain in the a** to get to if you have a/c.
p.s. the inertia switch is to the left of that fuse panel you posted a photo of.
Old November 4th, 2004, 12:32 PM
bjenk
Brian Jenkinson
1994 D90
Thanks guys for the quick info...It I do need to get a new pump I will let you know Evilfij. Oh, I do have the AC. I will let you know what I find out...It will be a while I have the instrument cluster out replacing a broken bracket and doing a little cleaning. Any concerns or solutions to the collection of dirt behind instument cluster?
Old November 4th, 2004, 07:33 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
My inertia switch on my 94 is on top of the fuses pictured, about in the middle.
Old November 5th, 2004, 10:51 PM
bjenk
Brian Jenkinson
1994 D90
Hey guys, I am still at work and doing a lot of searching about fuel pump/relays and came across this Post. Is it true I can not pick up a fuel pump relay from NAPA that will work. If I can do you know the Part #?
Sent: Monday, July 31, 2000 11:22 PM
Subject: [D90] stalling problem
Hey All
With regard to the suggestion of replacing the fuel pump relay--It is not a standard 4 pin relay on the NAS D-90. It is a special 5 pin relay with two outputs and (I think) a diode incorporated into it. It runs both the fuel pump and the O2 sensor heater circuits. If you fit a standard 5 pin relay you will end up with a dead battery as the O2 heaters will stay energized with the ignition off. There is no cheap substitute for this part.
Rob Dassler
Old November 5th, 2004, 11:50 PM
I got my relay from NAPA but it was a Bosch relay, this was for non OBII truck tho. FWIW
Old December 3rd, 2004, 10:53 AM
d901560's Avatar
d901560
Brian B
94 ST
Brian -
Did you get your truck running? I have the same problem. Fuel pump is not turning on. Fuse is OK. I replaced the fuel pump and it still will not turn on. (Ron, I have an used and most likley functional fuel pump available) I located two silver 5 pin relays next to the ECU. Which one needs to be replaced?
Denton, TX
Old December 3rd, 2004, 09:44 PM
Both.
Well either could cause the failure. YOu can buy one relay and swap each out individually.
I actually needed a dead pump which I got from Pendy.
Old December 4th, 2004, 08:39 PM
bjenk
Brian Jenkinson
1994 D90
Sorry for the delay and not posting the resolution to my problems. I was able to come by some relays online for $9.99 a piece (can't remember website, but have at home if anyone needs it). I just pulled the right one off and replace and when I turned the key to on you could hear the relay open and the fuel pump prime. So, in short it was just my fuel pump relay. I will now carry a spare with me at all times, the problem is getting to the blasted relays with a/c. If it happens again I will relocated them to the engine bay/passenger seat box. I have had the truck running now for about three weeks without a problem.
Old December 5th, 2004, 01:50 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would love to know where you got the relay from--could you post it?
Old December 5th, 2004, 09:00 PM
bjenk
Brian Jenkinson
1994 D90
Chris, looks like you were up pretty early...
I purchased the relays from:
www.thepartsbin.com
They are only $9.90 which is a killer deal compared to LR. I also got an oil pan gasket that I will install next time I tear into the 90. I can not remember the price, but it was too good to believe...
fuel
