Fuel pump: is this logical - Defender Source
Old July 21st, 2015, 05:51 PM
defender1844
Amit Likhyani
My truck has been in the shop for a few months and won't start. We are pretty sure we're getting power to the fuel pump but no fuel. I dropped the truck off with a full tank. The theory is the pump fouled from sitting in a full tank for so long without being used. Is this a plausible explanation? There is a trickle of fuel at the rail. We don't hear the pump when the key goes to on and the fuel gauge isn't moving off the far left. We are going to drop the tank and make sure there is voltage. We are able to see the connector at the tank via mirrors. Biggest issue is that the local dealer doesn't have one. I'm off this week and start a new job on Monday and really wanted to go into the weekend with the truck running. Any advice is appreciated.
Old July 21st, 2015, 05:54 PM
Did you replace the silver relays?
Old July 21st, 2015, 05:55 PM
Tarheeld
Bill
1985 110
IMHO. Put in an inline pump; way easier than dropping the tank and going through that hassle on a whim
Old July 21st, 2015, 05:57 PM
defender1844
Amit Likhyani
What are the silver relays? Please elaborate. Thanks evilfij.
Old July 21st, 2015, 06:24 PM
The two fuel pump relays under the passenger seat.
Old August 14th, 2015, 08:12 PM
sirjond's Avatar
sirjond
Jonny
1995 D90 ST Alpine White
First time ever - went to start the 90 and the fuel pump doesn't run at key turn - truck won't start. Should I try to replace the "silver relays" first? Also, I am no mechanic, are the silver relays inside the fuel injection box under the passenger seat or are they the two that are mounted at the back of the seat box?
any help would be appreciated.
Old August 14th, 2015, 10:28 PM
They are the ones mounted on the back of the seat box.
Old August 14th, 2015, 11:00 PM
sirjond's Avatar
sirjond
Jonny
Thanks, Jimmy!
I will give those a shot.
fuel
TD5 Fuel Pump/ pump tomaco1 For Sale - Parts 7 September 20th, 2011 09:13 PM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
Fuel tank skid / fuel pump / Dixon-Bate Tow Jaw chris snell Smaller Projects 16 September 2nd, 2010 12:29 AM
Diesel conversion - fuel pump removal and new fuel feed jaherring Defender Technical Discussions 0 July 19th, 2010 03:06 AM
Fuel pump and fuel gauge relationship question - troubleshoting... arbik Defender Technical Discussions 1 September 19th, 2006 02:31 PM
