Fuel Pump for 97? - Defender Source
Old September 11th, 2011, 08:53 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
Fuel Pump for 97?
I am wanting to buy a backup pump for the Defender. Does anyone know if it is the same as a Disco's? Just the pump not the whole sending unit.
Old September 11th, 2011, 09:26 PM
I used the GM/airtex E3240 part number and got one from autozone for about $75. Perfect fit. And yep it will fit Jill's truck too.
http://www.autozone.com/autozone/par...artNumber=true
Old September 11th, 2011, 09:42 PM
budzny
Real4X4
NAS 97 ST/NAS 93 110/62
Birthday Committee Team
x2.
Old September 12th, 2011, 08:38 AM
dchapman
Daniel Chapman
1999 D1
The only difference between the EVAP and Non-EVAP pumps is the electrical connections. I'm not referring to the entire fuel pump housing, because those are different. I'm talking about the pump itself.
The Non-EVAP trucks have small spade connectors for the positive and negative connections.
The EVAP trucks have a small wiring harness that connects the positive and negative leads.
You can put either/or in either truck. If you're putting a Non-EVAP pump into a truck that has EVAP, you just cut the wiring harness off and either solder the leads on, or use some small spade connectors.
Personally, I like the Bosch E3270 pump. The Bosch pump uses a metal propeller where as many of the others use a plastic propeller. The Bosch pump does cost a few bucks more.
Old September 12th, 2011, 08:40 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
I've had the extra Bosch pump sitting in "inventory" for a while now, but haven't found a part number for the strainer.
Any p/n for that?
Old September 12th, 2011, 02:21 PM
jijalicious
Jiman Khosravan
'94 D90
Will this one also fit 94 D90?
$80 beats $300 or so from LR.
Old September 12th, 2011, 04:11 PM
maleger
Marc-Andre Leger
same as last question
Would it fit a 94 (3.9l) ?
I was looking to change my fuel pump and that Bosch seems pretty sweet.
Old September 13th, 2011, 08:08 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Any p/n for that?
Delco TS7 should work.
My research came up with these two part numbers.
Airtex numbers.
E3240 (listed as for the 3.9):
- Gallons per hour: 40
- PSI shut off: 65-95
- Type: Rollervane
- Volts: 12
E3270 (listed as for the 4.0):
- Gallons per hour: 50-60
- PSI shut off: 80-90
- Type Rollervane
- Volts 12
That said, I used a Delco 3241 on my 3.9 about 5 years ago and no issues.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 13th, 2011, 08:27 AM
jijalicious
Jiman Khosravan
'94 D90
$43 for 94 3.9L?
http://www.amazon.com/Airtex-E3240-E...ar=1&carId=001
Old September 13th, 2011, 11:09 AM
61rover's Avatar
61rover
John Crouse
Strainer Part Number
Searched Autozone for the Airtrex strainer to go with the pump and about 100 come up. Does anyone know which is correct for the 3.9?
Old September 13th, 2011, 12:29 PM
Antichrist's Avatar
Antichrist
Tom Rowe
I used a TS7, as stated. It's slightly longer than the original, but works fine.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
jijalicious
Jiman Khosravan
'94 D90
Anyone? Anyone? Bueller?
Looks like John and I are on the same boat... neither of us is willing to dish out $300 for a pump from LR.
~Jij
Old September 13th, 2011, 03:49 PM
maleger
Marc-Andre Leger
Is there a part number for the Bosch fuel pump ?
That would be my choice.
Old September 13th, 2011, 05:30 PM
Came in the box with the pump when I bought mine.
97, fuel
