Fuel pump doesn't prime - silver relay? - Defender Source
Old August 15th, 2016, 08:42 AM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
On my phone and search is a bit tough at the moment.
Truck will crank, but no sputter. Fuel pump never makes it's priming sound when first turning ignition. I've checked the small fuse in the dash (#20).
I've relaxed the relay once in the past 8 years, and had the fuel pump changed almost one year ago. Before I head to napa buy a relay and take off the AC panel, are there any other suggestions?
"Uhh...I think they all leak like that."
Old August 15th, 2016, 10:04 AM
rovertrader's Avatar
rovertrader
Dale
Check wires and grounds first...
Old August 15th, 2016, 11:05 AM
There are 2 relays; a main, and the fuel pump relay. Pull your fuel pump relay and confirm you have power to the socket when the key is turned on. You should hear the main relay click with the fuel pump relay pulled. If you have power to the fuel pump relay socket and the fuel pump relay clicks when you plug it in with the key in the on position you need to drop your tank.
fuel, relay
Curent silver relay part #? wantone Defender Technical Discussions 10 September 17th, 2017 01:13 PM
Fuel Pump Prime? RhinoRover Misc. Chit-Chat 1 October 26th, 2015 06:06 PM
Silver Relay / Silver Relays rijosho Defender Technical Discussions 18 January 8th, 2012 12:07 PM
Fuel pump no prime? Check the connectors! Neil McCauley Defender Technical Discussions 2 January 12th, 2010 11:53 AM
Dropping gas tank on 110 again, fuel pump does not prime Neil McCauley Defender Technical Discussions 7 October 14th, 2009 09:25 PM
