fuel pump and relays? - Defender Source
Old September 11th, 2006, 01:16 PM
steved90
steven melnyk
hi guys ,still won't start, got stuck with the rig this weekend and finally got it home, changed the realys out, still can't hear the fuel pump go on? and my wipers and break lights don't work. what should i be looking at to get this thing running? i feel like i have tried and looked at eveything, let me know if any of you have any ideas what i should check next?
Old September 11th, 2006, 02:01 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Check your battery connection and ground straps. My dad's 90 had a stalling problem, turned out he didn't tighten the battery connection.
Old September 11th, 2006, 02:04 PM
steved90
steven melnyk
the battery connection is tight, still not starting!
boy this is frustrating
Old September 11th, 2006, 02:07 PM
btate
Bryan Tate
d90
you said you checked the large fuses in the engine compartment?
Old September 11th, 2006, 02:10 PM
steved90
steven melnyk
yup they are all good?
any other ideas??
Old September 11th, 2006, 03:57 PM
btate
Bryan Tate
d90
I am not an expert by any means, just trying to help here....but it seems like it would have to be a fuse or relay for several things to kick out like that. If I had a schematic close by I would check to see if there is a common fuse/relay for these items and start there. Are you sure you didn't short out the new relays? With that many things going out at once, it doesn't sound like a "part failure" (fuel pump wouldn't cause all these problems)
fuel, relay
YANST (Yet Another No Start Thread) - fuel pump circuit issues cgalpin Defender Technical Discussions 25 August 2nd, 2009 11:23 PM
Engine Dies: Fuel Pump & ECU Relays? jimngo Defender Technical Discussions 4 October 15th, 2006 01:25 PM
Fuel pump relay 95 D90SW alaskajgg Defender Technical Discussions 32 September 18th, 2006 10:26 AM
