Fuel pump and fuel gauge relationship question - troubleshoting... - Defender Source
Old September 17th, 2006, 04:56 PM
arbik
Arbi Karapetian
1995 D-90 SW #163/500
Hi guys,
So I'm still trouble shooting my D90.
I've eliminated the relays and the fuese as the problem. I'll be taking off the line from the filter to make sure of this. But I'm suspecting the pump to have failed. The truck has about 125K on it.
my fuel gauge works though, so can I assume from this, that since the sender/pump assy is a single unit, that there is electricity going to the assembly?
thanks,
-arbi
Old September 19th, 2006, 02:31 PM
arbik
Arbi Karapetian
For future reference...
Ok,
so since I found the answer to this, I'll answer it in case someone in the future does a search for the same question.
The answer is, you know at least for a fact that the connector is attached to the fuel pump assy.
the wires are separate though, but they do come in the same wiring harness, so chances are, if you can see fuel level, then your fuel pump is getting electricity, if you have juice at the relays.
-arbi
fuel
