Fuel pump? - Defender Source
Old September 13th, 2015, 10:25 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Fuel pump?
Hi all. So my mechanic buddy has been chipping away at my 94 NAS D90
Fuel issues. So he started at the injectors (replaced), then to the ECU (replaced), then replaced the filter (obviously), then power washed the tank as it had 10 year old gummy fuel residue.
My fuel pump runs. Mechanic thinks it should be replaced as the injectors are still not getting the proper pressure. Does that make sense? I always thought a fuel pump was either ON or OFF but didn't really do much for regulating or affecting pressure. Thoughts?
Thanks in advance for what may seem like a stupid question.
PS: coincidentally I already own a replacement fuel pump which I dropped off to him tonight. Long story.
Old September 14th, 2015, 04:57 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Bump?
Old September 14th, 2015, 08:54 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Hook up a fuel pressure gauge and see what it reads.
Old September 14th, 2015, 10:08 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Ok thanks.
Old September 14th, 2015, 10:19 PM
cascade90's Avatar
cascade90
Mason Worley
'95/NAS D90 SW #59/500
After you check the pressure at the fuel rail. It's one of two things. High or low. High is generally the regulator. Low is generally the pump. You can chk the regulator with a hand vacuum pump. If it holds a vacuum it's good. If it won't hold at all...the diaphragm has a hole in it. If you chk psi and low then you have weak pump. You should be up around 3 bar(43 psi) to be fat and happy. You have 3 filters in the system. One on the pump(20 micron), the in-line(approx 10micron) and the final one's are in the inlet of each injector(3-4micron). At this point I need more info to push you in the best direction. Good luck with your search...
Old September 14th, 2015, 10:21 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Awesome info. Working on it tomorrow afternoon. Update all to come. Thanks!!
------ Follow up post added September 14th, 2015 10:23 PM ------
Any likelihood that it could be the inertia switch?
Old September 14th, 2015, 10:31 PM
cascade90's Avatar
cascade90
Mason Worley
I don't have enough info to answer that. It is just a switch. Bypass it. Jump the wires. If same issue then no. Don't throw money at it. Enough of that kind of thing goin on. Remember you'll figure out what it isn't long before you figure out what it is. Give more info tomorrow and I'll try and help you out. This is a science at best.
Old September 14th, 2015, 10:43 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Awesome. Thanks so much for the guidance. More news tomorrow.
Old September 19th, 2015, 07:22 AM
BrianKelley
Brian Kelley
94 Defender 90 NAS
Hey Stephen- how'd you make out with this? I'm getting closer to installing new braided SS lines on my 94 NAS, so hoping I don't run into similar issues. I have a new fuel pump ready to go. I've been checking previous threads this morning searching for some proper pics of all the different fittings for the supply and return lines, but can't find anything expect for a barely visible diagram on RN. I've taken a lot of photos when removing the old lines, but just have that fear that i'm missing something and/or fittings go back on correctly. If anyone has detailed pics of OEM fuel lines, or replacement ones, that would help me out a ton
Old September 20th, 2015, 05:05 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Hey Bri. My mechanic buddy had this on hold for a week. Tinkering with it right now actually. Checking fuel pressure now... stay tuned. Thanks!
I'll text my buddy right now and ask for him to take some closeup photos. You have my number....text me exactly you want and I can likely get it. Happy to help.
Old September 20th, 2015, 07:23 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Brian,
I'm doing a engine swap from carbs to a NAS 3.9L EFI engine and just installed new fuel lines. Here are your options from what I gathered:
1) Replace the factory lines with OEM lines from Rovers North: Very expensive >$1,000
2) Replace the factory lines with after market US made Stainless Steel replicas by Classic Tube Still expensive in my opinion @$340 each, but what you get is an exact replica of the OEM lines.
3) Replace the factory lines with rubber hose and fittings: Inelegant, cheap, no longevity
4) What I did: Had new lines with compression fittings made by a local company (in SoCal) for $350 total. They are Teflon lines, wrapped in Stainless Steel braiding, wrapped in a black plastic jacket. They are high pressure, heat resistant to 500 deg., and fairly flexible. The fuel return line is one continuous length with a small section of rubber hose at the fuel rail, and a compression fitting at the tank. The feed line is in 2 sections, so I can have a "canister type" fuel filter fitted, with different fittings as needed.
Hope that helps.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old September 24th, 2015, 05:09 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
UPDATE: We replaced the fuel pump. My mechanic buddy checked the fuel pressure. It read 43-44 pounds. However, as we cranked the car to start, the pump shut off.
We made sure the inertia button is not the issue.
Is there a 2nd set of relays that we don't know about? We replaced the 2 relays under the interior/dash. 2 silver relays (with brown lines).
As a side test, we used starter fluid and the truck started right up and purrrred like a kitten.
What the heck???
Old September 24th, 2015, 06:29 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Did you use the specific FP relay? That relay is different from the other silver relays.
Old September 24th, 2015, 06:36 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Thanks Kevin. Not sure. Is that in the same relay cluster under the dash? I thought the fuel pump relay was one of the silver brown-line. Hmmmmm..
------ Follow up post added September 24th, 2015 06:37 PM ------
I called British Atlantic to order the relays. That's what they advised. I may have assumed the wrong ones to swap out?
Old September 24th, 2015, 06:52 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
You're probably fine if you got it from AB. I see they sell the black plastic ones now. The old silver ones had a red slash on the top and the relay base is blue (at least it is in the RRC).
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Cool. Same spot? I'm referring to the center area under the dash. Thanks!
fuel
TD5 Fuel Pump/ pump tomaco1 For Sale - Parts 7 September 20th, 2011 09:13 PM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
Fuel tank skid / fuel pump / Dixon-Bate Tow Jaw chris snell Smaller Projects 16 September 2nd, 2010 12:29 AM
Diesel conversion - fuel pump removal and new fuel feed jaherring Defender Technical Discussions 0 July 19th, 2010 03:06 AM
Fuel pump and fuel gauge relationship question - troubleshoting... arbik Defender Technical Discussions 1 September 19th, 2006 02:31 PM
