Fuel Problem, Maybe? - Defender Source
Old August 3rd, 2004, 03:36 PM
Crvn
Charlie Van Nostrand
94 Defender
fuel problem-maybe
Runs fine when cold-warns up and surges,sputters,etc like running out of fuel and stops. Can restart righ away with quick start but will not continue to run. Changed fuel filter and checked fuel pressure and all seems ok. Anybody got any ideas for a 94 d 90?
Old August 3rd, 2004, 03:47 PM
Did you check this out yet?
http://www.defendersource.com/faq/Engine/EngIgn.html
Old August 3rd, 2004, 04:34 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Also check your fuel pump relays.
Old August 4th, 2004, 05:14 PM
Crvn
94 Defender
Starts great cold, but when warms up it spits and sputters and quits. Will restart and run on starting fluid but won"t keep runing. It dies just like it ran out of gas. Have changed the fuel filter and checked fuel pressure and all seems O.K....any ideas out there in D-90 land (94)
Old August 4th, 2004, 05:22 PM
Charlie, did you forget that you already posted????????
Old August 4th, 2004, 05:33 PM
Crvn
94 Defender
Mike, Left hand, right hand. I'm new at this....sorry about the double post. Charlie
Old August 4th, 2004, 06:09 PM
No problem, I just wanted to make sure you didn't miss what was already posted.
fuel
Random & Intermittent Fuel? Problem popeohana Defender Technical Discussions 2 July 18th, 2005 02:47 AM
Strange Fuel Pump Fuse Problem mhill Defender Technical Discussions 6 July 11th, 2005 04:23 PM
Fuel Delivery Problem JOE BAGGS Defender Technical Discussions 2 January 7th, 2005 09:44 PM
Yet another fuel pump problem! TwisteD90 Defender Technical Discussions 17 June 9th, 2004 12:27 PM
