Fuel Pressure Gauge? - Defender Source
Old January 22nd, 2010, 05:43 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Trying this topic again, never did get any response the first time I tried it.
Has anybody been able to fit a fuel pressure gauge anywhere in a Hot-Wire EFI system? I'd love to put one in somewhere, but it's a serious pain in the ass so far from what I can see.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 22nd, 2010, 09:04 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Hans, I'm not sure I understand what the problem is. Why is it different putting one in a hot wire system from any other system?
Old January 22nd, 2010, 09:28 PM
Hans's Avatar
Hans
Hans Haase
Everybody else uses fittings threaded for normal sizes, and I can get off-the-shelf adapters if I want to put a dash gauge in. I could probably cut the factory fuel lines and put on some new flare fittings, but I'd rather not go that route if I don't have to.
For diagnostic work, everybody else has a schraeder valve right on the fuel rail that you can thread on a diagnostic pressure gauge. (or, again, normal threading on the connections). For us, there is some oddball gauge that you thread into the fuel filter, which I've never seen for sale anywhere.
-Hans
My oil line fix
Old January 22nd, 2010, 10:50 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Hans,
For diagnostic purposes, I took a new fuel filter, drilled a hole, and had a schrader valve fitting brazed in. You could also retrofit a Discovery fuel rail with the fitting.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old January 22nd, 2010, 11:11 PM
Hans's Avatar
Hans
Hans Haase
Originally Posted by Roadsiderob View Post
Hans,
What year disco's are we looking at for this? I have a THOR upper and lower manifold in storage, but those are dead-head regulated, aren't they?
-Hans
Edit: Ahhhh, saw one on e-bay. I see what you mean. Any differences in the fuel temp sender?
My oil line fix
fuel
Adding a fuel pressure gauge? Hans Defender Technical Discussions 5 December 7th, 2008 03:21 PM
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
How to check fuel pressure? Heath Defender Technical Discussions 3 January 11th, 2005 02:28 PM
Help wth Fuel Gauge (that works sometimes) ToyCrusher Defender Technical Discussions 14 October 20th, 2004 08:43 PM
