Fuel or ignition? - Defender Source
Old January 7th, 2011, 11:44 PM
jhhorse
joe heins
1995 defender 90
Fuel or ignition?
Help please!
I have searched the forum and cannot find this exact issue, so thought I would ask: 95 D-90 with 3.9, after driving for a bit, highway or around town, engine warmed up for a long time, after I turn the engine off for more than 5 minutes, when I start it back up, it idles ok, but stumbles a bit when trying to accelerate in first gear. once I get it going, it runs fine.
In addition, around 3200 rpm when accelerating any gear, it seems to reach a peak and will not accelerate any more.
It seems to me I have a fuel issue? Any help please. Thanks
Old January 8th, 2011, 10:27 AM
Well, Joe, it starts and runs so it's probably not fuel (assume new fuel filter). The next thing you have to look at is the spark. How long ago did you replace the cap,rotor, wires and plugs? Is the timing spot on? If you can answer recently and yes, then the issues may be connectors, sensors or dirt. Is the T-Piece clean?
Lots of stuff to check first before moving on.
Old January 8th, 2011, 11:12 AM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
If it is carburated, does it "stumble", as you mention, when you accelerate rapidly? Could be fuel starved. If dual carbed, could be a sync issue, float sticking, dirt, worn needle, air leaking into system, etc. I wouldn't expect a spark issue if it fires fine at idle. Might be a problem with the advance on the distrubutor if it happens at a certain RPM in each gear.
Old January 8th, 2011, 12:39 PM
Mike, I assume he's referring to the '95 model in his ID blurb. No carb there, just good old fashioned EFI. I suspect (in no particular order): ignition amplifier, cap and rotor, dirty t-piece, crappy gas, clogged fuel filter, dodgy fuel pump, low battery, bad ground, TPS, ACT sensor, fuel pressure regulator, air filter....
Old January 8th, 2011, 02:05 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Timing, clogged cats, O2 sensors...
Old January 8th, 2011, 03:26 PM
isleofbones
Mike Deery
1984 D-90
Bill-
You are right... I confused my engines / year as I am always (almost always) dealing with older ROW Rovers personally.
Old January 9th, 2011, 06:30 PM
jhhorse
joe heins
1995 defender 90
Thanks, That is where I will start. Plugs and wires fairly new, just changed fuel filter (cause its easy) and that improved it a little. Will change cap and rotor, check timing and let you know. Thanks
Old January 9th, 2011, 09:10 PM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
Sounds like an issue I had a couple years ago. Is the ECU throwing any codes? Eventually I changed the TPS and never had the issue again. "Knock on Wood" BTW, when the TPS finally gave up, it would only idle. Of course, I believe this is dependent in how the TPS is failing -- heard they develop "dead zones" in the poteniometer windings.
Old January 16th, 2011, 05:21 PM
jhhorse
joe heins
1995 defender 90
Fuel filter did it.
After changing the fuel filter and driving for a week, it appears these problems are gone!
fuel
