Fuel line replacements - Defender Source
Old September 21st, 2012, 03:30 PM
red&yellowrovers's Avatar
red&yellowrovers
Joe Still
95 D90 NAS 3.9l ST AA Yellow #2719
I have ruined my two rubber fuel lines that connect the pump/tank to the steel lines for fuel supply and return.
The local hyd shop says they can't find the threads to match for a compression fitting for custom made hoses.
I searched the archives and saw this question but never an answer. I'm sure half the people who have removed fuel tanks have trashed theirs, how are you reconnecting? I would suspect just push-on fuel line and band clamps at the connection to the steel lines after cutting off the flare nut. How do you handle the fuel pump connection?
Thanks in advance. js
Old September 21st, 2012, 03:59 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
when I did my fuel pump years ago there were none available. Now Stephen at Safari Rovers has them in SS...........
Todd
'95 D90 #2206
'66 109" P/U
Old September 21st, 2012, 04:17 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I just replaced my line from fuel filter to pump. I used some rigid brake pipe, 5/16", and got some new compression fittings. I cut off the brake flares and bent it up then used the threaded part that was already on the brake pipe. I know that it is supposed to be compatible with the brake flare end, but it seems to be holding the compression ferrule tight and hasn't leaked yet. Knock wood.
Old September 21st, 2012, 07:41 PM
d90xjay's Avatar
d90xjay
J Phillips
1997 D90 SW
Hmmm that sounds like good idea. I have my tank off the rover now wondering if I could get new rubber replacements or figuring out some alternate solution. My lines were corroded out bad.
Old September 22nd, 2012, 10:13 AM
red&yellowrovers
Joe Still
Looks like might be able to push on fuel hose over the crushed ferrule and then use band clamp. Not ideal but better than nothing. Js
Old September 22nd, 2012, 11:25 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
You can buy new ferrules at auto store for cheap.
I'm getting a rattle that I assume is coming from the hard line all the way from the fuel filter to the pump. I wouldn't suggest doing that. I'm going to change it out for some flex line and hose clamps
ac, fuel
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Fuel line valve cracking RickM Defender Technical Discussions 2 October 21st, 2004 11:15 PM
