Fuel line clogging 110 Tith - Page 2 - Defender Source
Old September 18th, 2015, 09:10 PM
The Dro
Dro
1988 Ninety
Originally Posted by rdavisinva View Post
Do they both work in a series?
Series 1, 2, 2A or 3?
Exactly who is on first... in the first place... score position.
Yes you can use both pumps in the same fuel system.
Doode... in series... not on a Series.
Fuel tank -> electric pump -> lift lump
What's the benefit of installing both together?
Old September 19th, 2015, 10:31 AM
carlosz's Avatar
carlosz
Carlos
doode, one or the other not both... on a drawing board you use the electric pump to bring fuel
from the tank to the lift pump, then the lift pump provides the amount of fuel the ip demands.
ip runs 3 to 10 psi intake (output to injectors is much higher), the electric is constant non variable pressure .excess pressure is then returned via return line to the tank.
thus in real application while not causing damage to the system, it is counter active to use both as at idle the manual pump will act as a dam much more than off idle speeds.
A word to the wise, a mechanical pump will leak but not stop working, electric will shut down completely upon failure.
not against them simply a shot of reality.
Old September 19th, 2015, 12:45 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If the electric pump quits, the left pump can draw fuel through it.
If the lift pump fails, the electric pump can pump through it.
Since the electric pumps are on demand and shut off with pressure, they have no problems with low or high delivery scenarios, because they are specifically designed for it.
RDavisinVA
Old September 19th, 2015, 06:24 PM
The Dro
Dro
1988 Ninety
Sooo... How about the Redskins?
Because I'm back to post #17
110, fuel
New NAS 90 Fuel Line Hoses (Line to Tank) FS SafariHP The Vendors Loft 0 August 28th, 2015 09:36 PM
Looking for list of all the brake and fuel line clips on a NAS 110 evilfij Defender Technical Discussions 18 May 16th, 2013 09:06 AM
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 09:03 AM
110 Fuel Line Coupling JimC Defender Technical Discussions 0 October 12th, 2009 02:00 PM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
