fuel injectors not working - Defender Source
Old May 24th, 2007, 05:54 PM
matt's Avatar
matt
Matt White
1994 Defender 90
I am having a similar problem as Jason in the last thread. My D-90 has had kind of a domino effect the last few days. It started out with a fuel pump that went out. I replaced it, drove it for about an hour, then went to start it back up and it would not start. It turns over, but doesn't start. My mechanic and I are stumped. All relays work, all fuses are in tact, but now the fuel injectors will not turn on, and it has an irregular spark pattern from the distributor. I pulled the ECM, and replaced a burned out mosfet circuit. Still nothing. Can anyone offer any more suggestions, as I am all out of ideas?
Old May 24th, 2007, 06:28 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Check the wire from the coil that triggers the injectors...make sure the injectors are getting the signal. Maybe.
fuel
