Fuel hose solutions... - Page 2 - Defender Source
Old April 12th, 2016, 02:55 PM
moceanman
Ryan Hewson
1995 d90
Hose Pics
I have these pulled out of my '95 D90 NAS so I'm posting them for perspective and discussion. These are the 2 hoses I'm trying to have built at a heavy equipment shop in Boston.
ID:	147046   Click image for larger version
Old April 12th, 2016, 03:10 PM
Any Parker hose shop can build you what you need. I'm usually amazed how cheaply and how much better the end product is over stock.
Old April 12th, 2016, 04:33 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Stephen in Florida made me a set for a very reasonable price. I know he had ordered a set of 10 and I took 2.
Worked perfectly.
Edit - Stephen's handle is SafariHP.
Old April 12th, 2016, 08:37 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
I had mine rebuilt in town at delta rubber for cheap. I was in a similar situation and I read that they were not 12x1.0 from some uk forums. I'm curious if yours work out.
Old April 12th, 2016, 11:04 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Interesting. I grabbed a 12mm x 1.0 nut (among several I tried) and it fit the male end perfectly, so that is where I got the measurement. So I hope it is right.
I also just found a 12mm x 1.0 to 6 an adapter at a speed shop so I may go that route instead of the smaller 4 an hose. Not sure if it matters either way though.
Old April 13th, 2016, 05:01 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Well that was a bust. Size and thread count are right but the internal diameter doesnt give enough depth for the pipe to fit in the nut. Gotta get back to researching.
Old April 13th, 2016, 05:56 PM
Broncoduecer
peter
D90
Rats! That would have been sweet. I've seen lots of 12x1.0 adapters, I bet you'll find something that works. Glad you have the threads figured out.
I wonder if steel will have a thinner wall and maybe fit better?
Old April 13th, 2016, 09:12 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Ya I may try to drill one out and see if it works. I just need to find someone local with a drill press.
Old April 16th, 2016, 07:28 PM
3.Fedhill fix; make up your own hard lines using Kinifex (nickle copper alloy) lines. Way better than SS and can be done by almost any idiot. If I have to tell you how I know this you are one. While you are at it explore the world of brake fittings and realize that you can be Stainless free!
Cunifer, you mean right?
Old April 19th, 2016, 07:57 PM
Naplm00
Matthew
I used blue urethane fuel line from parts unlimited and ss hose clamps. Works perfectly
Edit, shit sorry that was on a diesel
Old April 19th, 2016, 10:02 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Ya I think the pressure is too high with the fuel injection to just clamp it.
Old April 20th, 2016, 08:02 AM
moceanman
Ryan Hewson
1995 d90
fuel lines
Safari HP has them available on their website for $69/each.
I was trying to see if the local hydraulic shop could make me a pair, but he's a scientist about the whole thing and wants pressure and flow rates and blah blah blah.
I really wanted to go braided. The Safari ones don't have the corrugated plastic protection sleeve over them....I'm thinking I can re use the ones I have.
Will keep you posted.
~R
Old April 21st, 2016, 12:00 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
~R
You have a direct link for the SafariHP ones? I went to Defender > Fuel and Emissions and didn't see any.
Also my neighbor has a drill press, so I am going to try to drill out some 12x1.0 to 6an fittings that I picked up this weekend. I'll report back Monday on the status.
Old April 21st, 2016, 12:51 PM
moceanman
Ryan Hewson
1995 d90
Search part NASFUEL1
I will post permalink for the thread later (from my computer)
Cheers!
Old April 21st, 2016, 01:13 PM
Cheers!
https://safarihp.com/cgi-bin/commerc...n&key=NASFUEL1
Old April 21st, 2016, 02:34 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Originally Posted by Rocky View Post
Well that makes things a hell of a lot easier! Thanks!
Old April 25th, 2016, 11:49 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Originally Posted by wcampbel@nas.edu View Post
I guess I was hoping that someone had come up with a steel braided line solution, similar to the notorious oil cooler hoses.
So make some custom stainless lines. It's not very hard.
fuel
fuel filler hose mattdh Defender Technical Discussions 2 October 31st, 2003 08:17 PM
