Fuel guage out - Defender Source
Old March 2nd, 2013, 01:19 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Fuel guage out
Stopped working altogether. Just sets on E. Would this be a guage, sender, or fuse? If it is the sender I assume the tank has to be dropped?
Thanks guys.
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old March 2nd, 2013, 02:32 PM
michael67's Avatar
michael67
Michael White
110 Tdi
If the other gauges are working, I doubt it's a fuse. There are a couple of ground lines, though, so check both. You should also check the resistance at the gauge plug (I don't have it for the NAS - sorry). The tank must be dropped to remove the sender.
Old March 2nd, 2013, 02:42 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
What Michael said. All of your other gauges work off the same power, so if they are working it's not a fuse. You can pull the dash binnacle, and if you have a multimeter we can walk you through testing the resistance of the sender to see if it's working or not.
Old March 3rd, 2013, 07:57 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
On the internal fuel pump/level in the defender/RRC, there is a little braided wire the fails. Check that guage works. Then drop tank, pull pump and solder in a new braided wire. Dropping tank is the worst part unless you have a hatch in the tub bed. Took less than an hour total on my RRC (it has a hatch already)
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
fuel
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
fuel guage needle moving chirider Misc. Chit-Chat 1 November 20th, 2004 09:22 AM
