Fuel Gauge Problem - Defender Source
Old December 23rd, 2010, 01:51 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
Fuel Gauge Problem
Hi all,
My fuel gauge has been acting up lately. At first when I started the truck it would take maybe 30 seconds to work, now it stopped working altogether. Any thoughts?
Old December 23rd, 2010, 04:06 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
First thing I would do is test the ground on the gauge, probably the easiest thing to check first. Mine did the same thing and that was it.
Old December 24th, 2010, 01:54 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
I pulled out the dash, everything looked ok. Then I put everything back & now the turn signals, speedometer don't work. WTF?? Damn this thing is annoying!!!
Old December 24th, 2010, 02:47 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Well, Lucas is said to be called the "king of darkness". When one is making lights, this is strange. I suspect the wiring coming out of your sender unit. They rust coz of their location. Take your fuel gauge out and wire it this way: Negative to negative of battery. The other pin just put 12 v to it. It should indicate full. That way you'll make sure the gauge is or not your problem
Old December 24th, 2010, 02:56 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Does it work sporadically? If so, it could be in the wiring inside the frame, or there is a connection under the hood(bonnet) on the passenger side up near the hinge for the hood. I had corrosion in that connection, and then the wiring inside the frame. I just pulled it all and rewired it.
fuel
fuel gauge ohm range naeirie Defender Technical Discussions 35 September 6th, 2017 02:49 PM
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
Fuel Delivery Problem JOE BAGGS Defender Technical Discussions 2 January 7th, 2005 09:44 PM
Help wth Fuel Gauge (that works sometimes) ToyCrusher Defender Technical Discussions 14 October 20th, 2004 08:43 PM
