Fuel Gauge Pegged Full - Defender Source
Old September 6th, 2014, 12:26 AM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
When the ignition is off, it reads zero, but once on, it pegs above full. Stays that way and doesn't bounce. I'm sure that it's not the gauge
If there's a loose wire, would it peg high or low?
I have to drop the fuel tank to replace the rear crossmember and just wondering if I need to replace the fuel pump at the same time.
Old September 6th, 2014, 12:30 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Sounds like you sending wire might be ground? I had an issue like this once. Is this a new issue or existing? I think it's a wiring issue, but I could be wrong.
Old September 6th, 2014, 10:51 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
When this happened to mine I found upon removal that the float had become wedged at the top of the tank. What had caused this was I came down a steep grade & the hitch/bumper hit solid on a rock. My fuel level had been at about 3/4 tank when this happened so the float was already pretty high in the tank. So i guess the sudden shift in the fuel bounced the float upward & became lodged at the top of the tank.
fuel
fuel gauge ohm range naeirie Defender Technical Discussions 35 September 6th, 2017 02:49 PM
Fuel pump and fuel gauge relationship question - troubleshoting... arbik Defender Technical Discussions 1 September 19th, 2006 02:31 PM
bouncing fuel gauge mattdh Defender Technical Discussions 18 June 13th, 2006 02:17 AM
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
Help wth Fuel Gauge (that works sometimes) ToyCrusher Defender Technical Discussions 14 October 20th, 2004 08:43 PM
