fuel gauge ohm range - Page 2 - Defender Source
Old November 17th, 2007, 07:50 PM
True, but you can't get matching gauges for the other spots that will fit can you? Once you have one, you need the rest as the stock gauges look like crap afterwards. And the VDO Vision series will fill all the spots and more. Plus they are much cheaper.
The bounce is no problem. Like I say, the range is better than stock, so that is good enough.
Old November 18th, 2007, 12:53 AM
Cool John - good find. Now I'm going to swap out my fuel guages - thanks!
Old April 21st, 2009, 08:55 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Jim, how does the VDO fuel gauge work with the 95 NAS sender?
Legend in My Own Mind.
Old April 21st, 2009, 09:11 AM
I dunno, I never got around to the swap!
Old April 21st, 2009, 09:18 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
ok...
Old September 6th, 2017, 11:01 AM
DC_Bear's Avatar
DC_Bear
Bear
1984 Nintey
Upgrade time
My fuel meter accuracy is spotty at best. I've already replaced my speedo and tach with VDO Vision gauges so I figured it's time to swap out the fuel gauge too.
Summit Racing has the VDO Vision 301105 (2 1/16inch) for $25.44 so no problem there. The gauge reads 240-33 ohms which differs from what I gather the stock sender puts out 19-270 ohms. I would like to get as accurate a read a possible so I want to replace the sender too. Bosch and others sell 240-33 ohm level arm senders. Example of a $20 sender.
Before I order I was hoping someone on this thread might help me understand the OEM sender wiring. There are 2 wires on the stock sender (presumably 1 live + 1 ground) vs just 1 wire on all of the universal senders I've found including the Bosch sender linked above.
The OEM sender is attached to the fuel pipe, so I would need to modify any after-market sender to mount onto the round fuel pipe. This should not be too difficult, but I need to understand the wiring requirements. Can anyone help? Thanks
ID:	293009   Click image for larger version
If you can't fix it with a hammer and a wrench, then you probably have an electrical problem.
Old September 6th, 2017, 11:07 AM
The stock senders work perfectly with the 240-33 ohms gauge. I've put them in multiple trucks and the range of the gauge is just right for the Land Rover senders.
Old September 6th, 2017, 11:14 AM
DC_Bear's Avatar
DC_Bear
Bear
1984 Nintey
Red90 - That's great news and would certainly make my life easier. Just to be clear, the wider ohm range on the stock sender does not result in the gauge reporting full for longer or empty sooner? I assumed that if the stock sender puts out 38 ohms at 3/4 tank it would basically be showing as full (33 ohms) on the VDO vision gauge. Similarly, if the stock sender puts out 240 ohms at ~1/8th of a tank would the VDO gauge not read empty? I'm less worried about reporting empty early, but I'm trying to avoid the gauge reading full until I get to 3/4s of a tank and then dropping quickly to empty.
Old September 6th, 2017, 11:30 AM
The 270 and 33 is the E and F lines (not the total range of the gauge), which is pretty close to the same as the stock gauge.
The senders themselves have a wider range. Part of that is seen with the needle moving above and below the E and F lines and part is unused range as the float hits the bottom and top of the tank.
In any case, the range of the VDO matches the stock gauge well. When you run empty, the needle will continue past the E line and hit the stop before you run out of fuel. It will start to move from the upper stop as soon as the float starts to drop.
Old September 6th, 2017, 11:47 AM
DC_Bear's Avatar
DC_Bear
Bear
1984 Nintey
Perfect - Ordering the stock sender and VDO Vision gauge now. Thanks!
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Fwiw, I recently had the malfunctioning-from-my-purchase stock gas gauge on my '84 changed out for a VDO Vision without changing out the sender. My mechanic seemed 100% skeptical that changing out the gauge alone would fix the issue but it definitely did. I got it home & drained the fuel tank to check the reading & refilled the tank with a series of volumes & everything checked out. Good readings on that next fillup too. YMMV.
Old September 6th, 2017, 11:50 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Another +1 for VDO Vision + stock sender. The only "annoyance" is when the fuel sloshes on a partially empty tank, the gauge reacts to that and goes up and down. There isn't a damper built in to hide what is actually going on like many OEM fuel gauges have.
Old September 6th, 2017, 12:11 PM
DC_Bear's Avatar
DC_Bear
Bear
1984 Nintey
Since the sender and gauge are from different suppliers, maybe I will order just the gauge first and see if I get lucky!
Agree - The sloshing / bouncing is unwelcome. Is the damper an electronic feature of most gauges or something built into the sender itself?
Old September 6th, 2017, 12:27 PM
AdamSanta85
91' D90 200TDI
I imagine the gauge, but that is only a guess. This is the only aftermarket fuel gauge I have installed.
Old September 6th, 2017, 01:09 PM
Factoid's Avatar
Factoid
Mark
Three criminals seeking revenge
The damping is in the gauge and as you've seen, not all have it.
Also, there is no getting lucky. Any 240 ohms empty to 33 ohms full will work. I prefer Autometer, but any gauge with this range will work.
1976 Series III 109 "Montoya" ("You killed my father, prepare to die")
1988 Defender 90 LHD "Vizzini" (speed demon from Sicily)
1987 Defender 90 MOD LHD "fezzik" (giant rock thrower)
1975 Porsche 911 hot rod
1964 Porsche (Beck) 904
Old September 6th, 2017, 02:49 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I have a surplus TD5 fuel gauge if anyone needs one, PM me for details.
Works with the stock sender and has some dampening
fuel
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
Help wth Fuel Gauge (that works sometimes) ToyCrusher Defender Technical Discussions 14 October 20th, 2004 08:43 PM
