Fuel gauge gone wild - Defender Source
Old January 24th, 2009, 04:49 PM
flynn23
Scott Kozicki
97 NAS D90 SW
The needle in my fuel gauge has decided that it's searching for north rather than telling me how much fuel is in the tank. This happened within the last week. When the vehicle is level and still, it seems to indicate accurately, but while moving, it's uselessly untethered. I had my fuel pump replaced over the summer, and I'm wondering if the sending unit wasn't fastened properly. I'm really hoping this can be solved on the dash rather than having to drop the tank and open it. Thoughts?
Old January 24th, 2009, 04:52 PM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
Sounds like a ground to me.
Old January 24th, 2009, 08:28 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I would start by checking the wiring to the sender as it has a tendency to become corroded and cause issues. If not that, check the wiring to the gauge, but it is most likely the sender wiring that is fubar.
fuel
fuel gauge ohm range naeirie Defender Technical Discussions 35 September 6th, 2017 02:49 PM
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
Help wth Fuel Gauge (that works sometimes) ToyCrusher Defender Technical Discussions 14 October 20th, 2004 08:43 PM
