Fuel gauge empty at 1/2 - Defender Source
Old March 18th, 2014, 10:17 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Anyone have insight to fix my issue , my fuel gauge is reads from full to 1/2 full, just before 1/2 full the low fuel light starts flashing and when it hits half its stays lite solid (empty) it is a petrol V8 1985 110
Chris "V"
Old March 18th, 2014, 10:23 PM
My first inclination would be a bad fuel level sending unit, but it could be a problem with the wiring anywhere between the sending unit and gauge.
Old March 18th, 2014, 11:36 PM
Chris Velardi
Chris Velardi
1975 101FC
Can sending units be fixed or just best to replace them , Anyone in the US got them relatively cheep
Chris "V"
Old March 18th, 2014, 11:52 PM
Good news Chris, this proves your low fuel light works!
Old March 19th, 2014, 12:12 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
The ground path for the gauge is carried through the chassis. I would check/clean the ground and see if that is better. On my 84 i had a faulty gauge and sender. I replaced both and the the gauge read a little on the high side, I have since switched to the vdo gauge and have yet to run a tank through it so Im not sure how accurate it is now.
Ryan
84 110SW County LHD
07 L322 Vogue
Old March 19th, 2014, 06:27 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
It could also be a float that has a hole in it. After checking the wiring you may want to pull the sending unit to check it out.
Old March 19th, 2014, 08:08 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Had the same issue on my 1985 110.
When I replaced the tank and installed a new sending unit the gauge worked as expected.
RDavisinVA
Old March 19th, 2014, 09:22 AM
could also be a mismatch between sender and gauge if either have been replaced recently. unlikely but putting it out there.
Mark Kellgren
KM4BOR
Old March 19th, 2014, 02:44 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
My experience was, I'd had the fuel tank off and upon re-installation, reversed the lines at the tank. The return line doesn't go to the bottom of the tank, so it would "run out of fuel" while the tank was still half full.
Old March 19th, 2014, 08:35 PM
Chris Velardi
Chris Velardi
1975 101FC
My problem is the tank is empty at 1/2 full ( with idiot light on) . Stays at full until a 1/2 hour of driving then it drops to 3/4 get a flash every now and then , then it drops to half and she if out of fuel.
Chris "V"
Old March 19th, 2014, 09:24 PM
Then she calls you to come and rescue her!
This is a problem.
Old March 19th, 2014, 09:26 PM
Either the sender is bad or it is wired wrong then. The senders do wear out. They are pretty serious low tech....and cheap.
Old March 20th, 2014, 12:26 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
You can check the sender output by measuring the resistance to ground. It is really hard to say for sure where your problem lies without doing any further tests. The following ristance values were pulled from another post.
FULL - 19 OHMS
3/4 - 38 OHMS
1/2 - 67 OHMS
1/4 - 116 OHMS
Reserve - OHMS
Empty - 270 OHMS
Once you have tested at the sending unit you can then test at the gauge and you should have the same readings. If your readings match the above mentioned values your gauge is faulty. If they don't then your sending unit is faulty. Good luck..
Ryan
84 110SW County LHD
07 L322 Vogue
Old March 20th, 2014, 05:53 AM
Chris Velardi
Chris Velardi
1975 101FC
I'll pull and check it , thanks
Chris "V"
fuel
fuel gauge ohm range naeirie Defender Technical Discussions 35 September 6th, 2017 02:49 PM
D90 Fuel pump stays on jackaaaps Defender Technical Discussions 0 January 23rd, 2014 09:46 PM
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
Help wth Fuel Gauge (that works sometimes) ToyCrusher Defender Technical Discussions 14 October 20th, 2004 08:43 PM
