Fuel filter housing 200/300Tdi - Defender Source
Old April 15th, 2008, 02:09 PM
J4hand
James Forehand
83 110 200tdi
Here is a question for those with 200/300Tdi. My fuel filter housing has 4 connections, each number 1 to 4 with arrows indicating directional flow (I assume). I am using the two on the RHD side of the truck, an "in" and an "out." As far as the other two on the LHD side of the truck, the "out" connection is plugged with a bolt and the "in" connection has a threaded coupling with a one-way valve on it. This valve coupling started leaking diesel slowly. Can I just plug it with a bolt? What was it for? BTW, this 200tdi was out of a Disco.
James
300tdi, fuel, tdi
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
Replacing Fuel Filter...Should be easy right? Antonios Defender Technical Discussions 5 January 5th, 2006 09:38 AM
How to get d--- fuel pump housing back in NAS tank? Chris Cox Defender Technical Discussions 3 October 29th, 2004 09:58 AM
