Fuel filter banjo bolts and fittings - Defender Source
Old March 4th, 2012, 01:32 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
OK I need help again. I have a 200tdi that I changed the fuel filter housing to the proper one but now need to change the fittings on the fuel line to banjo style ones and can't find the parts anywhere. I have tried RDS and RN and TLR no luck. Here's the filter assembly and lift pump. Any ideas as to where to get these things? Thanks, Chris
also are pics of the old fittings a tapered deal
ID:	48559   Click image for larger version
ID:	48561   Click image for larger version
Old March 4th, 2012, 05:53 AM
This is the sort of thing you buy via royal post in the UK and have it shipped over. Much cheaper than buying in the us.
I just looked up ntc3346 (200tdi fuel filter banjo bolt) and britcar / craddock / paddocks carries them.
I have no idea what the part number is for the actual banjo itself...
Old March 4th, 2012, 07:17 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I got them all from:
http://www.lrseries.com/
Got them within a week
Old March 4th, 2012, 09:44 AM
From the UK would be the easiest. Personally I buy most all parts that way. Getting your own wholesale account is the only way to live...
ESR294 - Lift pump to filter: http://www.paddockspares.com/esr394-fuel-pipe.html
ESR395 - Filter to pump: http://www.paddockspares.com/esr395-fuel-pipe.html
NTC3346 - Banjo bolt: http://www.paddockspares.com/ntc3346-bolt-banjo.html
ESR354 - Washer: http://www.paddockspares.com/esr354-washer.html
The filter housing is though common in North America. When I was looking at alternatives, I took mine to a local diesel shop and they had a shelf full of the exact same filter housing. I imagine fittings are common as well.
Old March 4th, 2012, 10:07 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Speedway
Since 1952 America's Oldest Speed Shop ®
SINGLE BANJO STYLE FUEL FITTING, 5/16 INCH HOSE
Price:$16.99
Single Banjo Carb Fitting, 5/16" Hose Price: $16.99 EA
SpecsInfoFeaturesReviewsQuestions / Answers
91611067
Outlet Length0.78"
ThreadsRH Male
Thread Pitch1/2"-20
Hose ID5/16" (0.312")
Wrench TypeHex
Material TypeAluminum
Sold in QuantityEach
NotesUse replacement Teflon sealing washers 6174821 (9/16"x11/16") and 6174822 (5/8"x3/4") if needed
These fitting with the correct banjo bolts would get it done I believe. I can find these parts at most parts houses in the doorman or similar catalouge. A quick search brought me to speedway. The banjo bolts are used on many 80's to 90's european cars if you can get access to used parts local.
legend in my own mind
Old March 4th, 2012, 12:05 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've bought them from diesel shops that carry Lucas/CAV parts.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 4th, 2012, 01:24 PM
does ntc3346 include the banjo as well as the bolt? or is there a separate part number for the banjo?
Old March 4th, 2012, 11:16 PM
The banjo are only sold by LR with the hose as an assembly.
Old March 4th, 2012, 11:19 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
How do I get set up with a wholesale account in the UK and how much does that save you on average?
Old March 5th, 2012, 12:11 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
The old style hose that Chris shows in his pictures, is that 5/16 and are those fitting SAE or Metric. I'm adding a NAS tank to my exmod and need to tie into the existing system which looks the same.
bolts, fuel
Replaced fuel pump, truck won't start chris snell Defender Technical Discussions 1 July 23rd, 2010 12:29 PM
TDI Heated fuel filter Overlander Defender Technical Discussions 16 July 15th, 2008 01:03 AM
Alternative to factory fuel filter... TNRoverGuy Defender Technical Discussions 4 March 31st, 2007 05:34 PM
Door Sill (Carpet) Trim - D90 Wagon Kimos Defender Technical Discussions 14 October 28th, 2004 08:55 PM
