Fuel Filter - Defender Source
Old January 21st, 2005, 10:16 AM
milli's Avatar
milli
Michael D. Milliken
9590SW
Fuel Filter
Hey all,
I'm looking for a little instruction on replacing my fuel filter. Do i need to clamp anything off etc.?
Thanks in advance.
Old January 21st, 2005, 10:30 AM
To get rid of the pressure before removing any lines pull the fuel pump relay off and run the engine until it dies, this will drop the fuel pressure way down. There will still be fuel in the hose but it won't be under 40 psi of pressure, just be ready for some to come out when you unbolt the filter.
Old January 21st, 2005, 10:33 AM
I think when I changed mine I didnt do the pull the fuse trick, its easy to change your lines may be corroded so perhaps some PB Blaster to help things along
Old January 21st, 2005, 10:46 AM
milli's Avatar
milli
Michael D. Milliken
9590SW
Thanks. That's using the old hat rack.
fuel
Replacing Fuel Filter...Should be easy right? Antonios Defender Technical Discussions 5 January 5th, 2006 09:38 AM
Looking for a 300TDI Fuel filter EdHsu Defender Technical Discussions 2 September 12th, 2004 01:11 PM
