Fuel filter - Defender Source
Old December 6th, 2012, 02:56 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Fuel filter
Sorry dumb question but are there any tricks I should know before changing the fuel filter?
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old December 6th, 2012, 03:06 PM
If it is not rusty, no big deal, if it is rusty, there is an update kit for early fuel filters that has you cut the metal lines and has short little rubber lines which you can retrofit.
Also, make sure it is installed the proper direction. Genuine ones have arrows to show you. Probably also worth while to treat any rust on the bracket while you are replacing.
Old December 6th, 2012, 03:11 PM
PB Blaster
Old December 6th, 2012, 03:36 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Doesn't look like there is any rust. Will pb anyway. Any need to clamp lines or anything?
Thanks guys
Old December 6th, 2012, 03:37 PM
Thanks guys
I always just crack the line and cover with a rag until the pressure is gone and clean up the mess. By the book you are supposed to pull the fuel pump fuse and run until it stalls.
Old December 6th, 2012, 04:10 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
I've tried the fuel pump fuse trick but I still have a hell of a lot of fuel pressure on the line. If I loosen too much it sprays everywhere. Trying a slow drip but it is still dripping a lot of fuel. Should there still be that much after running w/o the fuel pump?
Old December 6th, 2012, 05:02 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Nevermind. Just had drain more than I thought. Thanks guys!
Old December 23rd, 2012, 02:49 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
With non-defender and defender experience with fuel filters on EFI cars, I always pull the fuel pump fuse with the car running and wait for it to die, and I've never had any spraying or significant fuel loss. If the system is depressurized it shouldn't spray, but its mostly just a safety issue.
fuel
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Replacing Fuel Filter...Should be easy right? Antonios Defender Technical Discussions 5 January 5th, 2006 09:38 AM
Looking for a 300TDI Fuel filter EdHsu Defender Technical Discussions 2 September 12th, 2004 01:11 PM
