Fuel Economy for TDI brain teaser - Defender Source
Old December 15th, 2007, 10:00 PM
My 2.8 has started to decline in it's fuel mileage over the last few months, going from 19.5 mpg 6 month ago, to 16.5 as of the last 2 tanks over the last 30 days. There hasn't been any change in driving style, and I"m wondering what has effected such a drop over time.
facts: I've run 2-3 tanks of biodiesel over last 3 months, but all my lines per Pendy are bio-ready. Temps have dropped from summer heat of 90's to 50-70's around here in last 30 days.
raised intake on entire time. air filters, water seperator and primary fuel filter replaced in last 2 months. it is about time for an oil change.
so what are the factors that can effect a turbo diesels economy, given same driving conditions?
Old December 15th, 2007, 10:43 PM
mpsteil
Michael Steil
NAS 110#23,97 ST#665
Tire pressure?
Old December 15th, 2007, 10:46 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Additives in the bio-diesel to lower the freezing temp. Same is done for regular diesel in the winter.
Old December 15th, 2007, 11:23 PM
Shane@EVS
Roverhybrids
Winter diesel is known to cause a drop in mileage
Old December 16th, 2007, 12:25 AM
One time, I had a remarkable drop in fuel mileage, and after popping the hood, I noticed my fuel returns had come undone and were dropping all the extra fuel on the ground instead of returning it to the tank. There was also an associated mess of course...
Old December 16th, 2007, 10:11 PM
I always see a drop in mileage in the winter in all my diesels. I assume it is due to the change in fuel.
Old December 17th, 2007, 06:21 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Like they said...it's the winter grade fuel. Expect about 10%-12% less mileage.
Matt Browne
Old December 17th, 2007, 11:01 AM
thanks all for your collective response. Anything that can be done to offset it? Do cetain boosters help?
Old December 19th, 2007, 11:24 AM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Do not underestimate tire pressure as a key factor...makes a diff of up to 4 MPG on my truck...also winter fuel of course...
George
Old December 19th, 2007, 12:33 PM
Cirbo's Avatar
Cirbo
Jim C.
Checked the Cummins and Defender. I've lost 2-3 mpg on each.
fuel, tdi
Misfire / Very poor fuel economy Jerry Defender Technical Discussions 14 November 13th, 2017 10:24 PM
