Fuel Delivery Problem - Defender Source
Old January 3rd, 2005, 04:44 PM
JOE BAGGS
JOSEPH BAGGS
Angry Fuel Delivery Problem
I DO NOT HAVE THE SCHEMATIC. I AM NOT GETTING POWER DELIVERED TO THE FUEL PUMP. I HAVE FOUND THAT I AM NOT GETTING POWER TO THE Fuel PUMP RELAY OR THE Fuel PUMP FUSE. Where does the power come from. Can anyone help with the schematic.
Joe Baggs
Old January 6th, 2005, 04:53 PM
brianbonner
Brian Bonner
1994 Defender 90
Lightbulb
I have seen this once before. It turned out to be a wire that came loose on the back of the ECU plug. Carefully check all the wires to ssee if they have broken off at the plug. I am pretty sure it was purple. But if you need me too I will look up the schematics for you.
Old January 7th, 2005, 09:44 PM
ripp2002's Avatar
ripp2002
L C
94 Defender 90
Fuel pump kill switch triggered?
Check your fuel pump kill switch thing. 95&97 are behind the air filter if I remember the picture someone put on my post. 94 is behind the fuses on the driver side. Not sure if that could be it but a suggestion
Good Luck,
Larry
fuel
Random & Intermittent Fuel? Problem popeohana Defender Technical Discussions 2 July 18th, 2005 02:47 AM
Strange Fuel Pump Fuse Problem mhill Defender Technical Discussions 6 July 11th, 2005 04:23 PM
Fuel Problem, Maybe? Crvn Defender Technical Discussions 6 August 4th, 2004 06:09 PM
Yet another fuel pump problem! TwisteD90 Defender Technical Discussions 17 June 9th, 2004 12:27 PM
