Fuel bleeding 2.5na - Defender Source
Old March 24th, 2016, 06:25 PM
bstauffer
Ben Stauffer
87 110 pickup
Fuel bleeding 2.5na
I just recently replaced two fuel lines that connect the fuel filter to the injector pump. After doing so I loosened the union bolt on top of the fuel filter in attempt to bleed the lines. The truck fired right up and will run all day and not stutter. But, after letting it sit overnight the truck has problems starting. It will start and run for a few seconds but then it quits and won't fire unless I pump the pedal. I don't think I bled the lines the right way. Tips?
Old March 24th, 2016, 06:46 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
The sandwich style filter has the return line plumbed back into the filter via a banjo.
This recirculates air that cannot be easily bled off.
When the TDI engines came out this problem got corrected.
It is almost impossible to get all the air trapped out of the system.
I recommend installing a sedimenter close to the tank, then a 12V fuel pump that comes on when the ignition is switched on.
This will expose any leaks as any area that was previously leaking will drip fuel.
Next get rid of the sandwich filter and install a TDI style spin-on or replace the banjo bolt on the return line with a solid bolt so the return line fuel actually goes back to the tank and not back into the sandwich filter.
With the 12V pump, you'll have a self bleeding system and you'll never have issues bleeding your fuel system again.
PM if you need a source for sedimenters and filters.
They are relatively inexpensive.
RDavisinVA
bleed, fuel
Self Bleeding Diesel Fuel System rdavisinva Defender Technical Discussions 2 March 30th, 2014 02:47 PM
Bleeding TDI Fuel System isleofbones Defender Technical Discussions 5 October 21st, 2010 04:47 AM
Fuel system bleeding CDNRover Defender Technical Discussions 6 July 16th, 2008 01:05 PM
brake bleeding redrover Defender Technical Discussions 2 November 18th, 2004 07:21 PM
Brake bleeding help!! Bowtracer Defender Technical Discussions 5 May 18th, 2004 02:24 PM
