fuel and temp gauge not working - Defender Source
Old June 30th, 2016, 11:16 PM
sheep_dog
Joe Anderson
1987 Defender 90
Hello every one, I just purchased a 1987 Defender 90. My fuel and temp gauge are not working. I have read multiple threads on how to diagnosis the problem. So today when I pulled the dash apart I could not find any bad ground wires. But there is a green wire that is unplugged from the wiring harness near the connector. The solid green wire does connect into the connector. I know that the solid green wire is part of both the temp and fuel gauge. So is this loose end causing my problem and where does it go? (see attached image) I appreciate the help in advance.
fuel
OEM fuel gauge, water temp gauge and tach defender1844 For Sale - Parts 4 June 27th, 2016 01:45 AM
95' NAS Fuel Gauge not working KKilo23 Defender Technical Discussions 6 June 3rd, 2014 10:41 PM
No brake lights, turn signals, temp or fuel gauge. John T Defender Technical Discussions 1 August 3rd, 2010 12:54 PM
Temperature gauge not working Jpayne Defender Technical Discussions 0 July 28th, 2010 08:46 PM
Fuel Gauge not working FlaD90 Defender Technical Discussions 6 February 20th, 2009 03:18 PM
