frustration sets in!!!!!new door tops - Defender Source
Old April 1st, 2010, 10:05 PM
hotroddef90's Avatar
hotroddef90
Rod Renfrow
1995 Defender 90 ST
Angry frustration sets in!!!!!new door tops
I am trying to remove my old door tops and cant make headway. i finally figured out it is an 11/16th socket but the damn NUT just spins and spins. i havent removed the door card cuz i dont want to unless i have to. anyone had issue with this? does wd40 work if i spray the threads? i thought this would take 10 minutes. uuuggghhhh!
AN HOUR AND A HALF AND A SIX PACK OF SAM ADAMS AND I HAVENT REMOVED ONE NUT!
Old April 1st, 2010, 10:12 PM
aosias's Avatar
aosias
Alexandra
1995 D90
http://www.defendersource.com/forum/...ght=door+studs
I let mine soak in that PB Blaster stuff for a night and then they came off.
Jamie Deck's Avatar
Jamie Deck
James Deck
95 Defender 90
Wd 40 is how i got mine off
Old April 1st, 2010, 10:26 PM
They are threaded into the door top itself too. Odds are you are spinning it inside the doortop. Keep undoing them while lifting up on the doortop and the doortop should separate from the studs. Then hammer the studs through the bottom of the door and then cut the nuts off with a dremel and buy new nuts. Then thread back in the door top.
Since yours are actually spinning (most of the time the stud seizes in the hole), it should be really easy.
Old April 1st, 2010, 11:17 PM
JRW's Avatar
JRW
94 D90 ST #1247
Originally Posted by evilfij View Post
...cut the nuts off with a dremel and buy new nuts.
Made me laugh. Must be the inner 8 year old
bjf -> Go to
and build a new defender.
phoenix37 -> If only it were that easy...
Old April 1st, 2010, 11:22 PM
I can remove the door tops in about an hour now. It is the first thing I do when I get a D90. Of course, the most recent D90 they popped right off (I cut its nuts off in 2002 when I first owned it hehehe).
Old April 1st, 2010, 11:38 PM
specops1526's Avatar
specops1526
Beluga '97 90
Better yet, buy the quick nuts so you don't have to deal with a socket to get the windows off again.
http://www.roverparts.com/Parts/9788.cfm?bc=ab
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old April 1st, 2010, 11:52 PM
phoenix37's Avatar
phoenix37
john
Considering the condition of Brians truck he speaks from experience. It must of been a nightmare to get those door tops off the first time..
Old April 1st, 2010, 11:57 PM
Originally Posted by phoenix37 View Post
considering the condition of brians truck he speaks from experience. It must of been a nightmare to get those door tops off the first time..
lol!
Old April 2nd, 2010, 02:46 AM
specops1526
Beluga '97 90
Ha...actually, John, my door tops were stuck on the very first time I took them off. I had to use a rubber mallet and a lot of force to pop them off. The nuts were stuck too. I found it easier to take the door cards off to access the nuts and studs. Just beware that the cappings might be corroded when you finally get the tops off. Mine were badly corroded and I had them redone 3 times. All thanks to the door tops trapping water under the rubber gasket and the gasket itself sticking and pulling the paint right off the cappings. I've vowed to never use the door tops again.
Take my advice, buy badger soft door tops...worth the money and convenience. John's getting them for his Jeep too.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old April 2nd, 2010, 08:35 AM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
A long while back someone fabed stainless studs, matched with the stainless quick nuts you get fairly free from this problem. however you will still see rusty water as the doorframe rots around the stainless you put in. I have a set of the original door top studs with little to no rust. If anyone needs them make an offer.
Old April 2nd, 2010, 08:47 AM
phoenix37's Avatar
phoenix37
john
[ John's getting them for his Jeep too.[/QUOTE]
Its more like a 66 Bronco than a Jeep but then again Land Rover knew that when they designed it.
Old April 2nd, 2010, 10:51 AM
gliebig's Avatar
gliebig
Greg Liebig
95 D90
Which quick nuts would be better?
I've had the ones from AB before....
which worked great. They would loosen occasionally, but no biggie.
Then , I found these from RN...
http://www.roversnorth.com/store/p-3...-set-of-4.aspx
I'm actually about to order a set, so which ones would you go with?
Old April 2nd, 2010, 05:32 PM
hotroddef90
Rod Renfrow
1995 Defender 90 ST
progress
finally some progress! I had to cut its nuts off with a grinder on one door, straight through the stud and it felt great! the other top came off with some duralube after sitting overnight. looks really cool with the windoms off, and i might leave it like that till winter.
thanks for advice guys.
Old April 2nd, 2010, 10:24 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
Hey this brings a thought to mind would there be interest for a run of Stainless Studs? If I can get the school shop to make up a bunch. Ill look into it next week if there is interest. Nt promising anything at this point I will ask though.
Old April 3rd, 2010, 07:20 PM
hotroddef90
Rod Renfrow
1995 Defender 90 ST
studs
ill take some
Old April 3rd, 2010, 07:51 PM
Pretty sure AB's are stainless and RNs are not, err well, someone makes them in non-stainess as that is what is on my red truck.
Old April 3rd, 2010, 10:27 PM
Mike, if they are making quick release nuts too I might be interested depending on price. I have studs already.
door, door tops
2x sets of springs Rover- Girl For Sale - Parts 0 March 24th, 2006 01:51 PM
2 Sets of Running Boards steved90 For Sale - Parts 10 March 2nd, 2006 02:28 PM
LR HD springs sets TDI Guy Misc. Chit-Chat 11 February 3rd, 2006 09:22 PM
S/S Window Stud Frustration chris snell Defender Technical Discussions 7 December 5th, 2005 09:16 PM
10 spline Series 2/2a/3 axles (3 sets) Seriesman For Sale - Parts 0 October 25th, 2004 12:53 AM
» Defender Registry
Classic
wchristie
Lloyd
rtcgb
Add your Defender
