Frozen Coolant - Defender Source
Old January 15th, 2007, 06:35 PM
Andrew Vick
Andrew Vick
95 D90
Frozen Coolant
As the picture indicates, it was -19 this morning, but the truck started up fine with block heater installed. Started down the road, and it started to overheat, so I pulled over, popped the hood and started checking things out. Top hose was hot and hard, but cold at the radiator. I got it into a shop, let it sit while squeezing the hose, and it worked itself out.
Any ideas on how to keep this from happening again tonight? Would a blanket over the radiator help?
Old January 15th, 2007, 06:42 PM
btate
Bryan Tate
d90
I was in your town this weekend....stayed at the Hotel Jerome.
Hoped to see a defender, but not a one. We did see alot of FJ 40's.
Yes it was cold there, didn't it get down to 9 degrees Sat?
Did you have some water mixed, was it burped?
Old January 15th, 2007, 06:57 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
Got a radiator muff?
Old January 15th, 2007, 07:01 PM
Andrew Vick
Andrew Vick
95 D90
Nope. I was wondering if slipping carboard in front of the rad might help. We don't usually get that cold, and it hopefully won't last until March.
Old January 15th, 2007, 07:31 PM
oldscratchggf
nate
95 d90
I would imagine that a radiator muff might be well worth the $40. Chances are you could use it in the future anyways.
Old January 15th, 2007, 08:26 PM
aloharover's Avatar
aloharover
Peter
1970 Series IIa 105
Rad muff won't help to prevent the rad from freezing over night. They are intended to limit airflow through the rad when driving.
Or do you think the contents of the rad were liquid until you started driving?
Block heater-is that an oil heater or coolant heater?
If the later, it is still possible that it doesn't put out enough to effect the rad.
Check the af-water ratio. You can get a device from any parts store that will let you sample the contents. Most likely the AF is low.
Old January 15th, 2007, 09:14 PM
Andrew Vick
Andrew Vick
95 D90
I think it froze up as I started driving, down a hill, low RPM's.
I'm thinking you may be correct on the AF mixture. I just replaced the coolant after removing the condensor last weekend.
The block heater is an oil heater, which is likely the only reason it started.
I secured some shop space for the evening so I'm good for tonight, but I will keep an eye on it. Absolutely shocking to watch the temp guage go to the right when the entire inside of your truck is frosted.
Old January 15th, 2007, 10:16 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
To be honest, it's just damned hard to keep a truck from freezing solid in weather that cold unless kept inside a garage.
Even if the block heater is able to thaw out the coolant and oil in the block, the stuff in the radiator is too far separated to keep from freezing. You need to be very careful about the ratio of antifreeze in there, and you may need to go with a higher percentage of anti-freeze in the mix.
I'm actually surprised it even started, it's amazing how little power a car battery can put out when it's that cold.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 16th, 2007, 02:58 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
How about your thermostat ?
How old is the thermostat.
I have not worked a whole lot on the Rover V8 but from my basic understanding of things that is where I would look.
We get realy cold weather up here, usualy around -20 celcius during a couple of weeks and some -30 celcius here and there but a rad to freeze up. Never seen it hapen. I would check your coolant mix for the approprat temprature and also check for a bad thermostat.
A Webasto heater or a block heater is always a good thing.
My 0.02 cent. Feel free to correct me if I'm wrong.
Pat
Kirk Lazarus, Tropic Thunder
Old January 16th, 2007, 03:05 PM
dameek
Dennis Meek
95 D90 #2826 Bought New
I see this has already written about, but I would immediately check the % of coolant to water. With a mixture of 1:1 your system is protected to at least -40F. Your cooolant should never freeze up when the engine is running. Would hate to see a LR engine destroyed.
Old January 16th, 2007, 07:48 PM
Andrew Vick
Andrew Vick
95 D90
New thermostat last summer with about 9,000 miles on it. When I cracked the cap yesterday, I did lose some coolant from the pressure, so I refilled with 100% coolant as I think the ratio may have been off. Keep your fingers crossed and I'll let you know tomorrow.
Signed, no warm shop tonight.
Old January 16th, 2007, 09:39 PM
MattGuyver_007's Avatar
MattGuyver_007
Matt VA
1995 D90 SW
Yes, you can even use 100% antifreeze during such cold weather. It was -29 in Steamboat last night and my antifreeze was fine here... stayed nice and fluid-like and even had a hint of warm air pouring into the cab.
Old January 17th, 2007, 02:20 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
http://www.jcwhitney.com/autoparts/P...001648/c-10101
Perhaps one of these might help! I use a mag unit on the oil pan but that only gives warm oil.
Old January 17th, 2007, 02:32 PM
Andrew Vick
Andrew Vick
95 D90
I think topping off with straight coolant probably solved it. No issues this morning at -11. I like the idea of the JC Whitney heater, as I have a magnetic oil heater and you're right: it only heats the oil.
Old January 17th, 2007, 03:54 PM
For like $30 you can buy a rover block heater from the dealer. There are two styles, one replaces a core plug the other I forget how it works.
Old January 17th, 2007, 05:25 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
the recirc ones are better
coolant
Engine Coolant what kinda rover4x4 Defender Technical Discussions 12 May 17th, 2009 11:02 PM
coolant - which to use scoloco Defender Technical Discussions 37 May 2nd, 2009 04:24 AM
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
