Frozen bulkhead bolts removal suggestions? - Defender Source
Old July 22nd, 2008, 05:11 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
So I had to cut the bolts off that hold the bulkhead to the chassis. Now I need to get them removed. Got any great tried and true tips for removing the frozen bolts from the bulkhead mounts? I have been soaking them for a week or so and no budge yet.
I have not tried really hard yet but thought I would put something out there to get some opinions.
Thanks in advance
Tyler
Old July 22nd, 2008, 05:19 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I assume you cut the nut off as it is easier to reach. Try turning the head of the bolt (which will loosen the rust) and then push or hammer it out. I've used 10 mm bolts to hammer out the originals
Old July 22nd, 2008, 05:31 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Yeah Chris no head to use unfortunately. I have tried to get a hold of it and turn it but nothing yet. Even tried some heat but that is hard to get it hot enough. Once I can get it moving then using a drift or even your idea will hopefully work.
Old July 22nd, 2008, 08:34 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
So nothing to hit with a BIG hammer?
Old July 22nd, 2008, 08:44 PM
hamiamham
mike
97 D-90
can u drill them out?
Old July 22nd, 2008, 09:53 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I wouldn't want to try and drill it out. Rust desolvers, heat, and hammering. Still seems like one end should be cut off and can therefore be forced thru the hole and to the other end? Once it moves, it will go thru.
Old July 22nd, 2008, 10:33 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
I have enough to grab onto on both ends but no go. I do not want to drill either. I might try welding a nut on one end and see if I can break it free by spinning it then start driving it out.
Old July 23rd, 2008, 01:53 AM
NashvilleRedD90's Avatar
NashvilleRedD90
Will Peters
'97 NAS D90 ST #1704 -4.6
Impact hammer with a round pointy chisel...
Oh BTW there are some spacers in there between the frame and the bulkhead so note the location of them...
'97 D90 - 4.6
'00 D2
Old July 23rd, 2008, 10:27 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Will we tried the impact a bit. Not sure how aggressive we need to be. But good idea.
Yeah I know about the spacers. Thanks though.
Good ideas keep em coming
Tyler
Old July 23rd, 2008, 10:49 AM
btate
Bryan Tate
d90
do you think using a floor jack to apply some upward pressure on the bulkhead may loosen any bind?
Old July 23rd, 2008, 11:23 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Bulkhead is off the frame and laying almost flat on the lift at eye level. Bolt is cut so it is just the shank in the hole. That is what needs to be extracted. So there is no bind on it at all. It is just simply seized in the sleeve on the bulkhead mount.
Old July 23rd, 2008, 11:40 AM
btate
Bryan Tate
d90
oh....my bad. Then some good "heat'n'beat" is in next
Old July 23rd, 2008, 04:29 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Heat and a BFH... IF you could weld a nut on it, then you can try turning it while heating and Beating
Legend in My Own Mind.
bolts
bulkhead removal ditskovich Defender Technical Discussions 16 April 13th, 2009 06:03 PM
Bulkhead removal bar Jase Misc. Chit-Chat 2 June 9th, 2006 11:49 PM
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
