front wings - Defender Source
Old January 16th, 2014, 11:05 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
front wings
First, my apologies to Landy_Andy for stealing his pic from the "for sale" section.
I need to replace some body panels on my D90. Part B is ok but need to switch out A. Is the front bezel panel just simply bolted on to B and C? Are there a bunch of rivets I need to drill out? If so, what size do I need to put it all back together? From the pic it seems like a combination of rivets and bolts. I haven't taken apart my front end yet, thought I'd first get an idea of what I'm up against, and also have the replacement part ordered, painted and ready to install.
Old January 17th, 2014, 04:26 AM
George has them
http://www.rdsparts.com/images/body/RTC6353.JPG
Genuine Land Rover
90/110 1993/94 NAS
Front headlamp panel
Right Side Only
RTC6353 $75.00
Old January 17th, 2014, 10:59 AM
If by "front bezel panel" you mean "A", then:
1. It is bolted to B
2. It is spot welded to C
Also, the "A" is composed of three parts. There are two that you do not see in the picture. One is the headlight mount panel, which is spot welded to the inside of "A", as well as an angled aluminum "lip" panel which is also welded to the inside of "A" (and is used to bolt to the spats.
There are two rivets IIRC, and many spot welds. You will need a spot weld drill.
Replace all spot welds with standard rivets.
There are three bolts holding the parts "A" and "B" together.
Old January 17th, 2014, 11:02 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Above answers it all well.
Easy to do, trickier to to neatly (i did one and it looked like a bit of a car crash, although the truck wasn't exactly a Bentley so it didn't matter)
If you know someone with a spot welder you could get it back to factory standard.
wing
RR Classic Driver's Front seat bottom access door jack frisch For Sale - Parts 0 February 27th, 2005 01:50 AM
D90 Passenger Front Fender (patch) ToyCrusher Wanted 4 February 25th, 2005 10:24 AM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
D90 ARB front bumper w/ winch mount taoseno For Sale - Parts 0 August 10th, 2004 01:41 PM
