Front Windshield Weather Stripping - Defender Source
Old February 26th, 2011, 07:19 AM
usadventureracing's Avatar
usadventureracing
Brett
110
I have cracks/holes in all 4 corners in the weather stripping. Has anyone replaced the weather stripping around the front windshield? Did you do it yourself or did you have someone else do it (a company that replaces windshields)?
Thanks, Brett
1983 ROW D110
1970 Series III (Parting out)
Old February 27th, 2011, 06:05 AM
paulnb57
Paul Beckwith
92 D90 300tdi hard top rebuild
If you mean the windscreen rubber between the screen and screen frame then it is a straight-forward job to do. As they age the rubber often perishes in the corners leading to leaks. To remove the old rubber and screen, don't muck about, just insert a Stanley Knife (box cutter??) or other sharp thin bladed knife between the glass and rubber and just cut the old rubber away ( The handle of the knife should be against the glass on the outside. When the rubber is cut all the way round get a pal to push the glass all round the edges to release it from the rubber, while you play fielder on the outside to stop it popping out onto the bonnet (hood). A blanket on the bonnet is a good idea to protect it. Clean up the flange on the screen frame then fit the new rubber to the screen, then insert a length of string (cord) into the groove in the rubber (that will go over the frame flange) Liberally lube the frame flange and the rubber with washing up liquid (liquid soap) then with one person outside offer up the screen to the frame as accurately as possible and press firmly against the frame. Your mate on the inside then pull one end of the string into the cab at about 90 degrees to the glass, while you push from the outside where he/she is pulling, which pulls the rubber over the flange with it, work carefully all round the edge of the glass until the rubber is all pulled through. You may have to thump(!!) the screen with your palm, around the edges, to seat it properly when the screen is in. It may take a couple of attempts as sometimes the string pulls through without the rubber and you have to start again.(keep pressure on the outside opposite where the string is being pulled) It helps if the string is about as thick as the glass......its easier to do than describe!! Its also easier if 3 of you do it, one to hold the screen in place, second to push on the screen from the outside opposite the puller and the third pulling the string. Clean up - job done - happy days!!
With the glass out its an ideal time to think about a heated screen or a different tint. This side of the pond some screens were clear and some had a light tint......
Good Luck
Paul
Ede Bibe Lude Post mortem nulla voluptas.
Eat Drink Play, After death there is no pleasure.
Old February 27th, 2011, 09:33 AM
usadventureracing
Brett
110
Thank you for the information, I may have to try it myself. Brett
1983 ROW D110
Old February 27th, 2011, 10:26 PM
Yes I have done this as Paul describes (2 people) and it really is that easy.
Originally Posted by pendy
I'm here for the D's
trip
windshield weather stripping advice... Grover Defender Technical Discussions 0 March 4th, 2006 02:28 PM
Need 95 D90 front Windshield Vadim Wanted 0 July 22nd, 2004 11:40 PM
weather stripping jstrong98 Defender Technical Discussions 3 April 20th, 2004 01:28 PM
removing weather stripping from door bottom JRowe Defender Technical Discussions 4 November 6th, 2003 01:53 PM
