Front Vent Issue - Defender Source
Old April 9th, 2010, 10:03 AM
Krna
Andy Krna
1997 D-90 ST AA Yellow
Front Vent Issue
Hey Guys,
Did a quick search but did not see anything similar to the issue I am having. My front fresh air vents will not stay open when I drive above 30mph. They stay open until they catch a gust of wind, and then they slam shut. Is there any way to tighten them?
Any thoughts or help is appreciated,
Andy
Old April 9th, 2010, 10:12 AM
Grover's Avatar
Grover
Thumbs up
It's possible the vent arm is not catching on the serrated teeth (catch) b/c the arm may be bent away. You could remove the vent and slightly bend the arm towards the serrated teeth (catch).
Cheers...
Old April 9th, 2010, 11:22 AM
imeek
Isaac
Red 94 D-90 (SOLD)
Perhaps the vents are not connected to the arms. Can you lift them up from outside the vehicle?
Old April 9th, 2010, 01:02 PM
Krna
Andy Krna
The vents are definitely connected to the arms. As far as the arm not cathing on the serrated teeth, that could be the fix, but it was not a problem before. They used to stay open, and then they got very hard to open/close at all so we sprayed some WD40 or silicone spray in the hinges and they loosened up. The driver side stays open, but not the passenger side. I could try bending the arm so it actually catches the teeth, but the teeth almost seem too shallow to be effective. Do the teeth actually hold it in other peoples trucks? Mine will move over into them, but spring out.
Old April 9th, 2010, 01:12 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
the teeth in a 97 must be different then because in mine the teeth are almost the full depth of the arm...
Old April 9th, 2010, 01:28 PM
KKilo23's Avatar
KKilo23
Kenny
I have a 97, my passenger side had the same issue. If you pull then vent apart, you need to re-adjust the piece that catches the teeth.
Old April 9th, 2010, 03:07 PM
Krna
Andy Krna
Thanks, will give that a go this weekend.
Old April 9th, 2010, 03:22 PM
CDeWan
Clay DeWan
5.3L beastie
Have the same problem on the passenger's side of my 94. Quick fix is to stuff a piece of folded paper or tapered dowel but that looks jenkie. I like Andy will need to remove and bend back into place the mechanism.
Tech question - How do you seperate the vent knob from the vent shaft - Help!
Old April 9th, 2010, 07:20 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
I have the same problem on the passenger side on my '95; why is it everyone seems to have problems w/ the passenger side?
Todd
'95 D90 #2206
'66 109" P/U
Old April 9th, 2010, 08:55 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
My guess is that because you have to lean your body over to reach that side, you occasionally throw a good deal of body weight into it when you squeeze it over to the right, and end up bending it past where it can spring back.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 12th, 2010, 09:06 AM
Krna
Andy Krna
Can the vent knob be removed, or do you have to take it apart from the outside?
Old April 12th, 2010, 02:40 PM
outfield
Steve
1995 D-90 SW #351
I found on my '95 that on the passenger side only, the slot in the plastic molding that the lever goes through is preventing the lever from fully engaging the teeth. I took a dremel tool and opened up the slot a bit so the lever would fully engage the teeth.
Black Plastic Front Vent Handle Frankie Carbone Defender Technical Discussions 8 November 16th, 2010 05:45 PM
Front Vent Flap Seals Flagg Defender Technical Discussions 14 February 20th, 2006 05:14 PM
Front Air Vent Lever Broke...Argh! boshea Defender Technical Discussions 5 February 15th, 2006 08:08 PM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
