front upper spring retainers? - Defender Source
Old June 4th, 2014, 05:14 PM
Does anyone have any suggestions for how to retain the front springs to the frame? I can't seem to find a manufacturer who makes upper spring retainers for the Defender.
I've read some posts on LR4x4 and AULRO which include suggestions like SS hose clamps and random bits of metal / screws, but what is the best way?
Old June 4th, 2014, 05:31 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Why not retain on the bottom and cones at the top?
Old June 4th, 2014, 05:33 PM
Some limiting straps would be a more elegant way of limiting travel rather than hose clamps.
Old June 4th, 2014, 05:43 PM
I don't want to limit travel - I want as much droop as possible. After comparing the performance of retain top/cone bottom vs. retain bottom/cone top on others rigs, it appears to me that retain top/cone bottom works best. In the front, there is no bottom cone, but that can be fixed in other ways.
Old June 4th, 2014, 05:44 PM
http://www.lucky8llc.com/Products.aspx?ProductID=2361
Old June 4th, 2014, 05:46 PM
Originally Posted by Red90 View Post
Thanks John - do you know how these actually attach the top spring to the frame without interfering with the shock?
Old June 4th, 2014, 05:47 PM
http://www.terrafirma4x4store.co.uk/...110_130_d1_rrc
That is what they are for. Ignore the picture at Lucky8....
Edit, maybe not.... Hang on...
Old June 4th, 2014, 05:48 PM
Oh okay, I didn't realise you wanted to fit cones on the bottom. I'm not into cones.
Old June 4th, 2014, 05:52 PM
Hmmm, can't seem to find them right now. My Google search power is low today.
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
How are those going to retain the top of the front spring?
OP, are you linked?? I run 3" RTE progressive springs up front, 11" Fox shocks, cones up top and Ballistic fab lower retainers, and the slotted radius arm bushings from Polybush. I can't get my spring to drop below the upper cone.
Old June 4th, 2014, 05:54 PM
As they say. Unless you are three link, there is not enough articulation available to unseat the springs.
Old June 4th, 2014, 05:55 PM
Some more details: I am planning on replacing the front shocks with longer units as the current droop on my front axle is a few inches - at the tire. I'd like to plan this modification in advance so while it isn't an actual problem right now, I'd like to have the right components ordered up front.
I'm pretty much sold on retaining springs at the frame after seeing RedRange's disco using that setup in the rear.
fish - I believe your springs are longer than mine. I am not linked, but that's not to say that I might not try a wristed arm or 3 link in the future!
Old June 4th, 2014, 06:01 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
On my D2 I droop low enough to un-seat the spring, so I hear where you're coming from.
Heavy Duty Lower coil spring retainers Front and Rear crown14 For Sale - Parts 1 January 11th, 2013 08:14 AM
WTS: 110 fuel sending unit, Terrafirma spring retainers, Land Rover Gear Sandals mcoleman762 For Sale - Parts 4 October 6th, 2011 09:13 PM
Spring Retainers TexasD-90 Defender Technical Discussions 14 January 14th, 2011 07:28 PM
Rock Ware Rear Spring Retainers Mr_Bodgers For Sale - Parts 8 April 13th, 2009 05:36 AM
Front spring retainers, where? artm Defender Technical Discussions 11 September 17th, 2005 01:12 AM
