Front U Joint exploded on Road trip home... have questions anyone. around Twin Falls? - Defender Source
Old November 28th, 2010, 01:56 AM
Coug D90's Avatar
Coug D90
Tristan Felchlin
1995/D90
So on my adventure from Ft. Knox, KY to Olympia, WA my D90 has suffered an injury. Outside of Twin Falls, Idaho a sudden vibration turned into a "boom, clang" immediately pulled over to discover the front drive shaft dangling from the transfer case. I disconnected the driveshaft and I managed to get towed into the parking lot of the hotel I was planning on stopping in. It looks like the u joint bracket on the differential end sheared the u joint looks to have suffered some dings when it rotated around but day light will reveal closer inspection...
So recommendations? How far can I go (safely) in 2wd. Anyone around the Boise/ Twin falls area?
Thanks for the help
Old November 28th, 2010, 02:12 AM
Defender90_218's Avatar
Defender90_218
Trenton Smith
1997 D90
Had the same thing happen once, you can take the drive shat all the way out and drive with the TC locked but just around the corner distances to be safe or to get to a shop, but other than that I wouldn't drive it too far or fast.
Old November 28th, 2010, 02:26 AM
Coug D90's Avatar
Coug D90
Tristan Felchlin
1995/D90
Pretty much looking like the yoke on the Differential end and the U joint are in need of replacement...
Old November 28th, 2010, 02:33 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I dont think that is 100% true
If you take the drive shaft out and lock the transfercase you can drive it in rear wheel drive as far as you want. I drove a couple hundred miles like that before, it is totally fine.
Check the rear U joint and grease them as they will be getting more load.
Old November 28th, 2010, 03:11 AM
Coug D90's Avatar
Coug D90
Tristan Felchlin
1995/D90
what is the max safe range i could baby it in this condition?
Old November 28th, 2010, 05:53 AM
The max safe range is as far as you want. Yeaste's front shaft went when I was driving from PA to GA right after I bought her. I pulled the shaft and drove a couple hundred more miles to my destination. Then I drove around for a week or two while I waited for parts. Its just not a problem.
Old November 28th, 2010, 06:10 AM
Defender90_218
Trenton Smith
1997 D90
Let me correct my comment, when I had this happen I did some other damage, so I only drove it to a parking lot then had it towed.
Old November 28th, 2010, 09:01 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
If you choose to drive in 2wd (I would) then you should probably go ahead and order parts and have them delivered to your destination. I know that simple things like u joints are not always easily found at local parts houses
Old November 28th, 2010, 09:35 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Napa 344 u-joints will work fine.
The driveline might sound a little clunky with out the extra load of the front prop shaft/axle/diff, but it's highly unlikely you'll do any damage driving in rear wheel only. Series Rovers did it for 32 years!
There are a bunch o' folks here that could probably get you a complete shaft anywhere you want it delivered by Tuesday am. Good luck!
Email is
Same place, new dogs.
Old November 28th, 2010, 11:33 AM
Coug D90's Avatar
Coug D90
Tristan Felchlin
1995/D90
Success rear portion of the front driveshaft removed from the Transfer case. Shaft itself looks okay... U joint will be on order, now I just need to find a yoke for the front differential.
Old November 28th, 2010, 11:44 AM
See if you can find a used one off a Disco 1.
Old November 28th, 2010, 12:16 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Why not just get a front from a D2. They are better anyway, right?
Old November 28th, 2010, 01:06 PM
You need a new t-case output flange to install a D2 shaft - they've got a different bolt pattern. Not super hard to swap, but not bolt-in either.
Old November 28th, 2010, 09:38 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I blew 2 driveshafts in Canada last September. Blew the rear one and then a day later the front went out. I nursed it to Maine and took a front driveshaft off Bruce's truck and drove 9 hours home on it. It vibrated like hell with the lift but I made it!
You should be fine on a single DS but when you let off the gas at high speed let off it slow so the slack take up isn't too bad
Old November 29th, 2010, 02:40 AM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Yup. I stopped chewing up U joints after doing the swap last year.
Old November 29th, 2010, 04:05 AM
Coug D90's Avatar
Coug D90
Tristan Felchlin
1995/D90
Update... Successfully made it the additional 600 some odd miles home... now to get on the business of fixing this
Old December 2nd, 2010, 07:41 AM
maleger
Marc-Andre Leger
Does any one have suggestions on axel and drive shaft replacements options ?
I went under my truck last week, while it was on a lift to install winter tyres. I saw the anti-sway bars where damaged, so I took them off (was in the plans anyway). I also saw that the axels where quite rusted. So I want to get some used axels and refurbish them and then replace the ones on the truck with the new units. After following this thread it seems like they may be options I did not consider (like D2). Any opinions on this ?
I can get axels and drive shafts pretty cheap from local scrap yard.
trip
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
Front and Rear diffs interchangable? castlerock4x4 Defender Technical Discussions 1 December 24th, 2003 03:11 AM
