Front TruTrac not right? - Defender Source
Old April 1st, 2014, 09:09 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
So I just got my truck back fron the getting a trutrac installed in the front diff (I trust the mechanic) but it now pulls to the left under acceleration only. When I let off the gas or engege the clutch no more pulling sensation. I have had a Detroit Locker in the rear for awhile and it was almost unnoticeable. There is some play/slop in my steering but not bad. It just seems weird. Any thoughts? Heading up to Wintergreen this weekend should I be worried?
Old April 1st, 2014, 10:39 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I found it! Torque steer is what I have. I guess it gets better when broken in.
Old April 1st, 2014, 11:32 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
How'd you figure that out? Locking the center diff and seeing if it continued?
Old April 2nd, 2014, 12:08 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
I have a trutrac front and rear... When I drive it always wants to self center. Should not be torquing to the side... All the literature I've read on them is that it centres your wheel which makes sense as it transfers torque to the tire that isn't moving as fast ( inside turn tire) which speeds that one up...
Old April 2nd, 2014, 12:20 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I have been busy withh the search tool and Clay talked a little about what I think I'm feeling. http://www.defendersource.com/forum/...light=tru+trac
Old April 2nd, 2014, 03:31 AM
CDeWan
Clay DeWan
5.3L beastie
Yep got torque steer for awhile with the TT and it went away after it broke in so for me I experience exactly what you did. I may be off base but I thought it may have something to do with unequal length half shafts
Old April 2nd, 2014, 05:55 AM
My Detroit rear was really tight at first. After a few thou miles it "softened" becoming barely noticeable as it unlocked and relived.
Old April 2nd, 2014, 08:35 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Thanks guys, yea my Detroit is barely noticeable in back, we'll see how she goes.
Old April 2nd, 2014, 08:52 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I have 90k + miles on my TT/Detroit set up. I'm also running 4:11's which tend to magnify everything a bit. My TT has been a trooper. About 6-7 years ago I was spinning at high speeds trying to exit a thick heavy sandy mud pit at MAR when my front DS twisted like taffy in two. TT never faltered.
Clay
Old April 2nd, 2014, 09:53 AM
Check tire pressures and wheel bearings. Any drag on one side or the other causes the TT to do that IME.
Old April 2nd, 2014, 11:00 PM
Greg S
Greg Sutfin
1986 90
One tire is newer or different pressure giving a different overall diameter and when both turn the same speed, one travels slightly farther causing it to pull to one side.
Old April 2nd, 2014, 11:35 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Bingo! Several psi difference between left front and right front. Will report back in the am if that cures it.
Old April 3rd, 2014, 10:41 AM
RickM
Rick Mabus
95 D-90 ST
Sounds like it did not take to long to break in. You had me a touch worried as this is the route I am going.
RickM
ac, ht
Used, excellent condition GBR-built TruTrac diff third members! - For Sale HeloBubba For Sale - Parts 1 April 2nd, 2013 09:51 PM
TruTrac 3rds with 4.11 Gears Wolf Fabrication For Sale - Parts 21 July 26th, 2012 06:22 AM
ARB or Trutrac Matt223081 Wanted 0 December 30th, 2011 11:42 AM
Detroit Trutrac mdmccallum Defender Technical Discussions 18 November 3rd, 2005 06:02 PM
TruTrac, 24 Spline Shafts, CVs mudrover For Sale - Parts 6 June 15th, 2004 05:29 PM
