front sway ber removal - Defender Source
Old June 12th, 2007, 04:25 PM
D901619's Avatar
D901619
oscar
if i remove the frnt sway bar do i need to remove the rear?
Old June 12th, 2007, 04:32 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
You don't _have_ to. In the UK, they do not come with the rear sway bar (at least a few years ago, not sure about now).
I removed my rear sway bar and kept the front one.
Road manners are affected, but then I don't drive like a maniac.
I never drove with both removed, but I'd assume it'll feel like a boat more than a truck (at highway speed or when making sharp turns).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old June 12th, 2007, 06:20 PM
I drove some without the front. I wouldnt reccomend, seems it could get a little out of control if you have to make a high speed manuever. Its fine without the rear though. I think the bolts on the front sway bar are 17mm
Old June 12th, 2007, 08:35 PM
i drov wth no swy bars 4 2 yrs & evrythng is fin.
Old June 13th, 2007, 12:45 AM
chrisconnie's Avatar
chrisconnie
Adam Hairston
97 LE #127/300
I chucked both of mine when I upgraded to OME springs and shocks. Don't miss em at all.
Old June 13th, 2007, 01:44 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Can a D90 front sway bar be installed on a 110 for road use? I can't imagine it takes too long to disconnect it for the trails.
Old June 13th, 2007, 12:22 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
My swy brs hv bn off 4 the 4 yrs Ive ownd the trk. No prblms.
If you upgrade to stiffer springs you'll hardly notice the difference. I swapped springs and removed bars all at once and noticed no difference.
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old June 13th, 2007, 01:00 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Mine have been off for about 7 years now -- with both stiff OMEs and now RTs and sensible shocks, even with 35s, there's been little difference in sway.
Old June 13th, 2007, 01:32 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I'm about to pull the trigger too. I have Med Duty springs, HD shocks, and 33" tires so I'll report back what the difference is like. I don't expect much.
Old June 13th, 2007, 04:12 PM
outfield
Steve
1995 D-90 SW #351
On my SW I run OME HD front and MED duty rear, OME shocks, 33 inch tires and no sways bars and it drives great.
Old June 13th, 2007, 04:49 PM
1of40's Avatar
1of40
1of40
Did any of you wild men extend your front brake lines to compensate for the extended travel?
Clay
Old June 13th, 2007, 11:33 PM
MonLand
Loic Fabro
Clay
Don't think this is necessary with the stock shocks.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old June 14th, 2007, 07:14 AM
Extended them anyway, it makes working on the brakes easier.
Old June 14th, 2007, 03:36 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Hey Clay do you want to drive my truck and see what its like with no sways?
Jimmy Buffett
Looking for a front anti sway bar Chaucer Wanted 9 August 24th, 2009 07:49 PM
fabbing sway bar mounts J.5 Defender Technical Discussions 1 September 13th, 2007 02:26 PM
Crushed front Sway bar mount on frame shawnpalmer Defender Technical Discussions 5 May 1st, 2007 12:06 AM
front sway bar mattdh Wanted 3 October 28th, 2003 09:23 PM
