Front suspension troubleshooting... - Defender Source
Old June 4th, 2006, 09:37 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I have this odd creaking issue coming from my front suspension. I just replaced the springs and noticed some geometry issues with the front. The car has a 2 inch lift, bilstein 7100 10 inch in the front, rovertym shock mounts (lower is eyelet mount) and 4x4 adventure gear front dislocation cones. When sitting flat the lower spring perch is angled forward and causes the spring to foward. The shock does not sit perfectly vertical, instead is seems the lower mount is further forward that the top mount so the shock sits at an angle. The result is the eyelets at both ends are stressed while sitting neutral in the driveway let alone off-road. When I shake the car the lower mounts in the front creak very loudly. I've wheeled the car all over, driven across the country and never had a problem but it just doesn't seem right. I feel like the radius arms need to be shorter or something. I don't know if i'm articulating this well but has anyone had similar symptoms happen?
Old June 5th, 2006, 07:22 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
If I am reading this correctly, the axle is angled forward a bit due to the 2" lift springs. To correct this, you have to get a set of castor correction radius arms or a Safarigard 3-link. THis will return your front axle to a more stock angle and make your casttor angle closer to stock..
Legend in My Own Mind.
front suspension
SafariGard 3 link front suspension cdb Defender Technical Discussions 36 June 8th, 2009 08:01 AM
Front Suspension Buckon37s Misc. Chit-Chat 17 November 27th, 2006 01:02 AM
Sliding down the slippery suspension slope souza Defender Technical Discussions 18 February 3rd, 2005 11:06 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
