Front spring retainers, where? - Defender Source
Old September 15th, 2005, 05:41 PM
artm
Arthur Maravelis
97 SW
My Racho's are too long for the front. Anyone recall who sells the front spring retainers?
Old September 15th, 2005, 06:12 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Try John C at http://www.4x4ag.com/html/suspension.htm
3rd low and BOOT IT
Old September 15th, 2005, 09:02 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
If you want upper spring retainers too, just go with some heavy duty hose clamps. Put a couple on each side. You may have to replace them every once in a while, but $0.50 each is a lot cheaper than buying some real spring retainers, there'll just be a little work involved.
Old September 15th, 2005, 09:28 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
Expedition Exchange sells great spring retainers. If you haven't already done so you'd need to remove the shock cone from on top of the front spring seat.
Old September 16th, 2005, 01:14 AM
jabber
m j
110
Go to the hardware store and pick up some bar stock & bolts.... then make your own for a couple bucks!!!!
Old September 16th, 2005, 01:22 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
What he said
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old September 16th, 2005, 08:26 AM
artm
Arthur Maravelis
97 SW
Did that on the rears - kept coming loose.
Old September 16th, 2005, 09:28 AM
jabber
m j
110
Red Locktite and Nylock nuts or lock washers.
Old September 16th, 2005, 01:02 PM
cbass's Avatar
cbass
Bradlee Duncan
Old September 16th, 2005, 03:16 PM
I know what Art is saying, mine come loose too, I think I am going to try hammering the end down around the spring. My problem is not the bolts get loose but the spring rotates and get's loose.
Old September 16th, 2005, 09:10 PM
jabber
m j
110
Does anyone have any idea how much force would be needed to keep the spring seated?
Reason I ask is... what about something like a hose clamp only much heavier duty?
Old September 17th, 2005, 01:12 AM
cbass's Avatar
cbass
Bradlee Duncan
Hose clamps work fine, you might break them here and there, but they're cheap to replace so it's no big deal. Just use a few of them on each spring.
Rock Ware Rear Spring Retainers Mr_Bodgers For Sale - Parts 8 April 13th, 2009 05:36 AM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
