Front speaker wiring issues - Defender Source
Old February 8th, 2004, 03:21 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Ok, since day 1 my front speakers keep intermittently quitting on me. Sometimes 1, sometimes both. Back speakers never give me a problem. Was going to upgrade anyways, so I put in some known good speakers that I already had.... still have the problem. Had a known good radio I wanted in the truck, so swapped that out too... still have the problem.
So, that means it's in the wiring between the speakers and the radio. Any particular place I should look at?
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 8th, 2004, 03:27 PM
Chaucer
Will
93 110 | 97 90
You might start with where the wire connects to the door inside the flexible rubber tube. Then start tracing it back.
Old February 9th, 2004, 02:10 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
I haven't looked into this, but when I called crutchfield about adding a new deck, they said "your speakers share a common ground." I suppose, rather than the normal procedure, there's some wire that runs between the two, rather then grounding separately? p.s. mine do the same...looking to reqire it all...
Old February 13th, 2004, 08:34 PM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
Hey Hans
I have to run, but the little "Clarion" amplifier has been the source of many problems for my 1995 d-90. Check under the passenger seat compartment... The wires all end up there. If you have a powerfull head-unit you might want to cut the amplifier out all together. You probably noticed the difference in coloration between the speaker wires in the doors, and in the speaker wires that connect to the head unit. They change in that little amp in the passenger seat compartment.... once you see it, it will all make sense.
Has anyone been able to keep that "amp"?
I just cut it out... one less part to go bad.
You can splice the wires (with plenty of room to spare under there). But maybe someone dissagrees... wait a bit to see what other people have to say.
Old February 13th, 2004, 11:38 PM
If you cut it out the sound level will not be as loud as it is now, but it should work. I can't see it hurting anything and you can always hook it back up if it doesn't work.
wiring
Speaker wiring advice/help NASD90 Defender Technical Discussions 18 May 28th, 2005 06:50 PM
Front Speaker Grills RFA Wanted 3 September 2nd, 2004 03:50 PM
speaker wiring? rover4x4 Defender Technical Discussions 23 February 2nd, 2004 05:49 PM
