Front speaker in seat box - Defender Source
Old December 8th, 2017, 08:54 AM
goater
mark bradley
2000 Defender 110 TD5
Sorry i know there has been loads of discussion in the past about speaker placement but ive got long legs, air con, and no previous speaker placement. I have been looking at placement options for the speakers in the front area and it struck me that i could place them in the front surface of the seat box facing forwards and slightly up. Despite battery location and CPU there is plenty of room in both. Every other option is facing back wards and towards the floor or in the door which i know will get kicked every time i swing in and out with snow boots on. Any thoughts on the suggestion or experience would be gratefully received.It a 2000 110 TD5
Old December 8th, 2017, 09:12 AM
I like the tray across the top of the windshield option. You'll have to build one, but it makes many problems go away.
Something like this:
http://www.consoles.com.au/Rover_LandDefender_shelf.htm
Old December 8th, 2017, 10:00 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Or LaSalle headliners have a multitude of options, including speaker and radio pockets:
Products | LaSalle Interior Trim
Email is
Same place, new dogs.
Old December 8th, 2017, 10:22 AM
don't do it?
I'd recommend sticking a small bluetooth speaker on top of your dash pad with velcro before cutting into your aluminum or trying to mod your vehicle to fit speakers.
just slap a soundlink mini or micro on top of your dash and enjoy the music without having to do much work.
Old December 8th, 2017, 10:48 AM
Factoid's Avatar
Factoid
Mark
Three criminals seeking revenge
I enjoy music and wanted good tunes in my 90. I wanted a good set of Focal component speakers. In this case, 6 3/4” woofer with a separate tweeter. As part of my LS install, I removed the clutch pedal and most of the rear bulkhead which allowed me to lift slightly and push back my seat by about 3”. I then installed speakers in the foot wells using these enclosures. BTW, im 6’4” with big feet. I used these enclosures:
https://www.crutchfield.com/p_044QLU....html?tp=61423
I’m not suggesting this location for you, but these enclosures give you options with out cutting huge holes in your seat box or bulkhead.
1976 Series III 109 "Montoya" ("You killed my father, prepare to die")
1988 Defender 90 LHD "Vizzini" (speed demon from Sicily)
1987 Defender 90 MOD LHD "fezzik" (giant rock thrower)
1975 Porsche 911 hot rod
1964 Porsche (Beck) 904
Old December 8th, 2017, 12:06 PM
The JBL Flip 4 is pretty awesome. Waterproof and take-with-you portable when you're done in your truck.
Old December 8th, 2017, 07:18 PM
Naplm00
Matthew
I use pioneer ts-cx7 speakers they are 4ohm 60w center channel speakers... No longer made but you can find them.
They mount right on top of the dash with velcro
Old December 11th, 2017, 11:45 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
cubby box
I mounted my 'rear' speakers in the cubby facing rearwards. I used the Retro Sound dual coil 5x7 speaker mounted low to the inside rear of the cubby and the radio itself to the inside front. I cut out a hole for the speaker, put a piece of open wire screen over the hole (for some protection) then covered the rear of the cubby with a thick speaker fabric. I reused the original cubby liner plus some of the same British textured cardboard I had around to reline the interior of the cubby around the speaker.
The sound is not perfect, but is more than good enough for me (AM, news and the occasional CSN&Y song) and is discrete. There is also a fair amount of storage remaining in the cubby. PM if you want pics or details.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old December 11th, 2017, 11:52 AM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
MUD UK rear speaker enclosures allow larger rear speakers, powered sub on back of console, standard dash placement for fronts, with tweets up top.
Noico or DynaMat is a must.
Is your TD5 running well?
KGH - “Stinky LR diesel” Defender Snob
Old December 12th, 2017, 09:20 PM
Lemonhead
TB
1997 D90 SW
Not sure about putting main speakers in seat box but couple companies make thin powered sub with 8" speaker that will fit under NAS passenger seat without problem. Important to have sub in noisy defender.
No cutting needed - Bass is non-directional and you don't need to "see" the woofer in most cases.
I have one in my SW and sounds great.
Check this page for options.
https://www.crutchfield.com/g_51000/...ml?tp=114&pg=1
As for "main" speakers - I sourced some jeep enclosures for the Series that give some options.
seat box
FS: D-90 Parts (Bikini Top, front bumper, wagon seat back cover, shift lever bezel dzientek For Sale - Parts 5 March 16th, 2005 12:09 PM
Used 97 D-90 front seat Seriesman For Sale - Parts 6 September 21st, 2004 01:49 AM
