Front shock stupid question! - Defender Source
Old May 24th, 2011, 09:44 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I looked for pics everywhere but didn't find anything.
Where the heck do all the rubber bushings go on the front shocks?
I figured 2 on top and one on the bottom.
But theres still an extra 2 bushings?
I can't see how 1 would go under the spring plate on the front axle
Old May 24th, 2011, 10:20 AM
James Pierce's Avatar
James Pierce
James Pierce Jr.
I hope this makes sense
The shock tower and the spring perch on the axel both get sandwiched with a rubber bushing and washer on top and bottom.
Old May 24th, 2011, 10:30 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
It does make sense, I just didn't think it would fit under the perch.
Old May 24th, 2011, 10:36 AM
achampagne's Avatar
achampagne
Adrian Champagne
06 LR3 HSE
I think RN has small diagram in the catalog showing you the correct installation
Old May 24th, 2011, 11:24 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Putting the bottom nut on the shock can be a bit fiddly, but it should have a bushing and washer.
Tony
1984 110 "Smokey" (sold)
Old May 24th, 2011, 01:38 PM
mattarm's Avatar
mattarm
Matt
1993 D110
attached
Old May 24th, 2011, 02:01 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Crap! I just finished and the washers are in like the pic on the right.
Old May 25th, 2011, 11:20 PM
Tino.R's Avatar
Tino.R
Tino Rebelo
67/series IIA
Tom i hope you didn,t do that in front of the kids.
Old May 25th, 2011, 11:26 PM
The lower ones, that is correct.
The washers fit to "cup" the bushings.
Old May 25th, 2011, 11:34 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
What wrong with putting the top bushing washers like pictured on the right?
Old May 26th, 2011, 12:17 AM
Nothing. See my post above.
Old May 26th, 2011, 07:43 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
I believe you can break the end of the shock if the shock cannot move side-to-side a few mm. I'm just guessing here. Maybe it won't break the shock but limit it's movement (mainly when flexing the suspension offroad).
John C.
Old May 26th, 2011, 09:07 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I also assumed they should cup the bushings since the OME kit didn't come with a picture like that. I had to guess so all 4 shocks are installed like the "how not to do" picture on the right. I get the lower washers but why the top ones? Articulation? Do I really need to change them all?
Old May 26th, 2011, 09:44 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Did you look at them when you took everything apart?
Old May 26th, 2011, 10:22 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Yep. Put them back the way the old ones were installed so I guess Rover's North got it wrong too because they installed the last set. I even asked ARB (OME) if there were special instructions and they said none were needed.
Stupid, Stupid, Question bstraw Defender Technical Discussions 3 February 23rd, 2006 08:48 PM
Rockware front shock mounts jorge Defender Technical Discussions 1 May 25th, 2005 11:48 PM
external front shock mounts? brianbonner Defender Technical Discussions 9 January 11th, 2005 05:06 PM
front shock mounts krisp Misc. Chit-Chat 2 December 17th, 2003 11:22 PM
