Front shaft hitting the Cross member - Defender Source
Old September 22nd, 2009, 09:32 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
After putting on the 2" shock lowering towers on it seems like the front shaft is hitting the crossmember. I was wondering if this is normal and how I can fix it? I have the 200tdi with the old school crossmember from an 1985.
Old September 23rd, 2009, 03:33 AM
There should be some play in the holes for the crossmember so you can scoot it down a 3/8ths of an inch or so.
Old September 23rd, 2009, 06:09 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Good point, that will prob do it. I have those wiper things for you ron.
Old September 23rd, 2009, 08:47 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
You are talking about the front driveshaft contacting the transmission crossmember correct?
Why would lowering (or raising) your shock mounts cause your drive shaft to get any closer or further from the front crossmember? Shocks should not make much of a diffrence in amount of lift you have and if you are using the same old ones it should not change the lift at all.
Are the shocks the proper length for your mounts?
Is it almost touching it when sitting on flat ground? Will lowering it 3/8 be enough to clear when the suspension flexes?
Sounds fishy to me
Old September 23rd, 2009, 08:49 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Im talking about when its on the lift in the shop.
Old September 23rd, 2009, 08:54 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
ahh you were talking about when it is on the lift, you have more droop with the lower shock towers, that makes more sense then
Try what Ron said, if that does not work you could always try a limiting strap.
Also make sure your shocks are the proper length and do not bottom out as that will kill your shock.
Old September 23rd, 2009, 09:17 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
And make sure your brake hoses are long enough for the added down travel.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old November 13th, 2012, 10:26 PM
tomaco, how did you fix this? I found the same issue on my truck
Old November 25th, 2012, 08:22 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I ditched the 2' lower towers
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 07:14 AM
Rf Rack install ? front cross bar placement paulb Defender Technical Discussions 0 June 12th, 2005 03:52 PM
New Safari Gard 3-link cross member Davis For Sale - Parts 2 July 4th, 2004 05:00 AM
front drive shaft jorge Defender Technical Discussions 6 December 9th, 2003 11:23 AM
