Front seatbelt (90 / 110) correct PN help? - Defender Source
Old June 29th, 2016, 11:04 AM
Looking at replacing the front seatbelts and am finding some (unsurprisingly) conflicting information on the web:
BTR6561 / BTR6562:
These look newer and don't seem to attach to the old-style brackets (345100 / 345101). Are these fine for installation into any 90/110? I'd rather use these if I can, because I don't really like the old-style brackets on the seatbox.
or:
FF001187 / FF005940 or
MXC5492 / MXC5493:
Seems the same as what I have installed current on my 1984, with the older style bracket attachment to the seatbox. Are there any seat belt PNs that work best?
thanks in advance!
Old June 30th, 2016, 01:37 PM
It looks like Exmoor Trim PN EXT001-5 and EXT001-6 are similar to the BTR part numbers, with the added advantage of including the early looking female buckle.
Anyone else using the BTR part numbers? I know the BTR parts do not come with the female buckle, and the puma female buckles are quite different from early buckles...the puma has a two-bolt mount bolted to the seatbox/tub, as well as a different style of tub reinforcement.
Old June 30th, 2016, 03:32 PM
Tarheeld
Bill
1985 110
I used some surplus Humvee military seat/belts which were a perfect fit. PM me if you want more details.
BTR6561 / BTR6562:
or:
MXC5492 / MXC5493:
thanks in advance!
Old July 3rd, 2016, 06:19 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
Hi, I used the RN RSB003/4 on my 90 w the only necessary mod being a thick washer under the stalk end to clear the metal lip on the seat box in front of the bulkhead. Those look to be the same ad your btr6561/2. I like the higher lap belt mount as the belts don't seem as eager to get caught on the door latch. Losing the crud catching lower brackets is also a plus.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old July 3rd, 2016, 08:57 PM
Thanks Wayne!
Old October 30th, 2016, 09:39 AM
mteibel@nc.rr.com
Mitch
1985 ROW Ninety
Per Tarheeld's earlier post the - Humvee ; 3 POINT SEAT BELT - Fit like a glove on my ROW 90. 45 minute install for a non-mechanically inclined member ... $40 delivered for both the LH and RH belts.
110, 90, seatbelt
Seatbelt help Noyac40 Defender Technical Discussions 4 October 7th, 2016 06:59 AM
Front Seatbelt - 110 3 Door JohnsD90 Wanted 10 April 19th, 2016 12:22 PM
WTB: Defender Front Seatbelt Tarheeld Wanted 4 April 1st, 2016 11:57 AM
Help w/bolt specs- D90 rear seatbelt Bradford Defender Technical Discussions 2 May 16th, 2013 07:40 AM
WTB front seatbelt female catch assemblies ThriceLandy Wanted 4 December 16th, 2009 09:52 PM
