Front Seat Reclining Gear/ Ratchet - Defender Source
Old May 31st, 2015, 08:18 PM
rtgoldenb's Avatar
rtgoldenb
Tyler
1997 D90 NAS
It appears that my passenger seat reclining gear/ ratchet thing has become worn down and unable to effectively hold the seat in position.
Unfortunately the half that is attached to the seat is the worn down side (red circle).
I believe that the subframe side (green circle) is still properly grooved.
Is there a way to fix this without buying a new seat?
ID:	121921   Click image for larger version
Old May 31st, 2015, 09:23 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
From the pics the teeth don't look so bad. Are you sure you pressed the seat adjusting lever all the way down until it locks? You might have to hold the seat back and rock it until the lever locks.
Old May 31st, 2015, 09:52 PM
rtgoldenb's Avatar
rtgoldenb
Tyler
1997 D90 NAS
I didnt think the teeth looked that bad either. It will hold if i put all my body weight on the lever, but will still often slip over time.
I think im going to take my driver side apart to compare.
Old May 31st, 2015, 10:57 PM
rankar's Avatar
rankar
Maybe just get the upper seat assembly? Great time to replace foam or fabric if you've been wanting to
Also, make sure the seat bracket assembly itself (the long bars on the base) is not loose or broken. If it is, this could be introducing some play in the latch, especially when weight is put on it
B&M Pro Ratchet Shifter The Dro The Flea Market 6 November 5th, 2013 10:50 AM
Escape Gear Seat Covers Oliver Whiting The Vendors Loft 9 April 8th, 2012 09:48 PM
Has anyone ever modified the rear bulkhead bar so you can install reclining seats? Neil McCauley Defender Technical Discussions 10 August 31st, 2011 12:43 PM
Seat Reclining Mechanism RH Cover MWC7636 Manimal Wanted 2 July 24th, 2011 11:35 AM
Mac tools 3/8 flexhead ratchet mightymg For Sale - Parts 1 February 6th, 2010 10:29 AM
