front salisbury diff removal - Defender Source
Old December 22nd, 2012, 12:05 PM
defenderizl's Avatar
defenderizl
leon bonhomme
defender 110
I,m running into a problem removing the diff from my front axle. Is it true i need an axle spreader. i was assuming i only needed that at the rear. please help
Old December 22nd, 2012, 12:14 PM
Never done a front sals, but if it is anything like a front 60 you either need the spreader or you need to pry it out.
Old December 22nd, 2012, 12:29 PM
defenderizl
leon bonhomme
defender 110
strange the exploded diagram seems to be straight forward unbolt
Old December 22nd, 2012, 02:33 PM
defenderizl
leon bonhomme
defender 110
i've got all the other stuff off and the axle on stands. allso the halfshaft, bearings cv joints, brakes, swivel housing etc, etc, out/off. so now i would like some movement. so prybar you say. Good to know that i can go neantherthal on it now.
Old December 22nd, 2012, 03:46 PM
defenderizl
leon bonhomme
defender 110
Got it out !!! Jipieeehhhh
And looks like new
Old December 22nd, 2012, 03:53 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Ummm that does not look like Salisbury, looks like the standard rover diff
Old December 22nd, 2012, 04:00 PM
defenderizl
leon bonhomme
defender 110
Strange, pretty sure it,s a salisbury.
------ Follow up post added December 22nd, 2012 03:01 PM ------
It's the front one
Old December 22nd, 2012, 04:33 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
It's the front one
If it was a Salisbury it would have a diff cover like a traditional axle and not a complete 3rd like you have.
Semper Fi!
Old December 22nd, 2012, 05:35 PM
defenderizl
leon bonhomme
defender 110
Ok you must be right.
Old December 22nd, 2012, 08:12 PM
you definitely don't need any spreader tp get a sals rear diff out. they fall right out every time. Never seen a salisbury front axle in the 100's of early defenders I have dealt with so not able to help.
Old December 25th, 2012, 05:34 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
The front salisbury arn't that popular, even over here. they fetch good money (i've had one on an old 110)
Halfshafts and CV's are no stronger than normal though... they share the same CV joint depending on 23 or 32 spline shaft.
The chrome swivel is stronger on a salisbury axle though, although a "normal" one will fit right on.
I've got the parts list here for the salisbury 110 front axle here, if anyone wants a copy (.pdf) fling me yer email.
GBR or similar axles for Salisbury axle 110 or regular front diff.. the rover shop Wanted 26 October 26th, 2012 10:32 PM
Salisbury Diff Guard - Bar Type - Galv JohnC For Sale - Parts 1 May 8th, 2012 12:56 PM
Help, front diff is toast... Mybluett Wanted 7 April 2nd, 2012 05:26 PM
Front diff flippedrover Wanted 11 October 29th, 2006 09:10 AM
Any opinion on QT services Diff protection? COSteve Defender Technical Discussions 21 October 28th, 2004 06:17 PM
