Front Runner Slimline Rack on NAS 90 (Front Cage Issue) - Defender Source
Old September 23rd, 2016, 11:23 PM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
Been reading lots of threads on the FR Slimline Rack, most of which are several years old, but I can't seem to find a conclusive answer to if anyone has solved the mounting on the cage issue with the front-cage of a NAS 90 (as the legs can't reach the gutter due to the cage).
There was something from Manimal saying he'd designed a mount but couldn't find anyone to fabricate it that sounded most promising.
Has anyone figured out a solution?
Old September 24th, 2016, 05:53 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
To solve it you're going to have to fabricate something. You can find the weld on roll bar steel clamps on eBay so you do not have to fabricate those. Make sure the height is level with whatever FR rack foot you decide to go with (same height). Defenders Northwest also has a roll cage clamp that could work for you. Check their website.
Old September 24th, 2016, 07:42 PM
brettm's Avatar
brettm
Brett
any idea what clamps on ebay? the 1.5" ones seem most common, but i thought the cages were 45mm. i can't find those on fleabay...
Old September 25th, 2016, 04:47 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Here's the fix. This will work if you are using the short Front Runner mounting legs (220mm) for the other 4 legs.
Front Runner FRONT leg for the LR3/4 roof rack & a GenRite 1-3/4" tube clamp.
The base of the LR3/4 FRONT leg is steel, weld it to the GenRite 1-3/4" tube clamp.
Shorten the bottom of the LR3/4 leg by ~1/2", drill a hole in it & attach to the base.
Be sure to contact FR by phone, they willing exchanged the LR3/4 legs for the 220mm's at no additional charge.
ID:	158390   Click image for larger version
Old September 25th, 2016, 05:44 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I believe its 1.75" for NAS cage. See here.
Old September 25th, 2016, 10:53 PM
brettm's Avatar
brettm
Brett
perfect - thanks guys. i love an excuse to break out the welder
Old March 2nd, 2017, 11:16 AM
brettm's Avatar
brettm
Brett
@viton - called front runner today and they said the LR 3/4 legs won't work as they are laser cut and one peice. Sounded like this was a change in design. Maybe you used and older generation? They didn't offer any advice due to the "variation in cage widths" and said need to be custom fit.
Guess I'll have to make my own
Old March 2nd, 2017, 11:48 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
I have two of these clamps if anyone wants them. New in box. I thought I needed them to put my surf rack on my truck but I was able to do it without messing with the roll bar. You might able to fashion a no weld solution
https://shop.safetydevices.com/colle...ant=1045807469
Old March 2nd, 2017, 09:46 PM
cascade90's Avatar
cascade90
Mason Worley
'95/NAS D90 SW #59/500
Adam, I sent you a PM. At your convenience. Thanks
Old April 28th, 2017, 11:19 PM
AdamSanta85
91' D90 200TDI
How far off the roof does the front runner rack come off the roof? I want one but I need to be able to clear my garage entrance.
Is it 10 inches? Or is it 10 inches from the rails. If so does anyone know the height difference from rails to highest roof point?
https://www.frontrunneroutfitters.co...imline-ii.html
Old April 29th, 2017, 07:43 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Adam, check out the ARB rack in person if you've never seen one on a 90. It fits, imo, like a glove and looks like it belongs on a 90. All the feet, front to back mount to the rain gutter. Jimmy in Brooklyn I believe has one on his truck.
Old April 29th, 2017, 07:56 AM
AdamSanta85
91' D90 200TDI
Cool ill take a look. My buddy has a Front Runner on his Tacoma. While I think it looks a little weird I love how flexible it is. They make so many nice mounts for it for various items (high lift, surfboards yadda yadda). They even have a vertical surfboard mount so you can still load the rack up with other stuff. Also it is pretty low profile which I need due to my height requirements. My truck JUST makes it in with the current Thule cross bars on it.
Edit: Yea that ARB is sharp looking. Can the side rails come off? That is my only chance of making the garage.
Old April 29th, 2017, 08:42 AM
1of40's Avatar
1of40
1of40
Not on the models I've seen. They take a beating. I've seen them rubbed up against trees on tight trails with no damage. Tools and storage I'm sure they have mounting apps but boards I agree you probably want a flat rack.
Old April 29th, 2017, 04:53 PM
cjbenway's Avatar
cjbenway
Chris Benway
1984 LR 90 ( Hedrick Rover )
If it helps anyone.
Here is a pic of my Frontrunner rack with the larger(taller) mounts.
ROW though.
Old April 29th, 2017, 09:16 PM
cascade90's Avatar
cascade90
Mason Worley
Adam, I measured mine with the standard/non-high rack. From the floor of the gutter to the to of the rack is 10 5/8". I hope this give you something to work with. I would suggest verifying your truck is level and use the highest point.
Old November 28th, 2017, 08:33 PM
AdamSanta85
91' D90 200TDI
I asked Front Runner about this. They must have changed the design of the LR3/4 rack. Your solution is by far the simplest.
My rack came in the mail today.
Old November 29th, 2017, 01:00 PM
AdamSanta85
91' D90 200TDI
I found these 1.75 tube clamps from Ruff Stuff Industries that should serve me well as a base to build my front mounts. What makes these special is that they are 3" in width which matches up with the width of the Front Runner mount. A lot of roll bar clamps on the market are only 1.5-2" in width.
Ruffstuff 1.75" OD Tube Clamp - RuffStuff Specialties
Ill update as my progress continues. I think I am going to try to emulate what Viton did by welding a tab onto the clamp, and then bolting the Front Runner leg to the tab. Seems to be the simplest, most cost effective solution. What Manimal had made (CNC alu clamp/bracket) is gorgeous but expensive.
Old November 29th, 2017, 01:26 PM
brettm's Avatar
brettm
Brett
PM @CDN38 - apparently he was doing a similar install a few months ago and figured out a good solution.
Old December 9th, 2017, 05:00 PM
AdamSanta85
91' D90 200TDI
My friend from Taurus Auto fabricated/welded the clamps for my rack today. Nice and sturdy. I just need to send the new assembly out for powder coat.
Old December 9th, 2017, 06:15 PM
Noyac40's Avatar
Noyac40
1985 D110
Adam, That looks great, nice job on the clamps. Thanks for showing us your rack!
90, ac, cage, nas, rack
Front Runner Slimline Roof Rack Question Ben Dutton Defender Technical Discussions 66 October 20th, 2017 02:05 PM
Front runner slimline ii full rack d110 for sale jamaycan For Sale - Parts 10 July 27th, 2016 02:26 PM
WTB - Front Runner Slimline Roof Rack kurtisblo Wanted 2 July 27th, 2016 03:34 AM
Front Runner Slimline II Racks curry For Sale - Parts 17 October 5th, 2014 08:54 AM
Front runner slimline II rack Ncrover725 Defender Technical Discussions 2 May 28th, 2014 12:55 PM
