Front Rotor Swap.. must break hub seal? - Defender Source
Old March 13th, 2010, 01:28 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
I've got a 97 D90 with just under 60K. My front rotors (and pads front/back) need to be changed. I was told that on a 97 D90 I don't need to get into the hub itself when putting in new front rotors. Is this true? Do they essentially just bolt on?
I was also suggested that unless the bearings are making any noise or there is play then why change them. However if ultimately the seal needs to be broken when putting on new front rotors I guess I might as well put in new bearings (?).
Thoughts?
Old March 13th, 2010, 01:46 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
the rotor bolts to the back of the hub, so you have to remove the hub anyway. It's probably a good time to repack the bearings and put new seals in, since they are cheap and you have the hub off anyway. I did the job for the first time last summer and did not find it too difficult. I also put a little bit of antiseize on the mating face of where the rotor meets the hub to make future removal easier.
However, technically, you do not need to "get into" the hubs, I believe it is recommended to repack the bearings every 30K so yours are probably due.
Old March 13th, 2010, 05:41 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
After looking more closely that makes sense. I'll go ahead and order the bearings and do it right. Why do these projects always grow like a virus!? Arrgh! I appreciate the advice.
Old March 13th, 2010, 05:52 PM
yeah its a must to repack/seal the bearings. You might as well go ahead and pull the entire swivel down and check the preload on both sides.
Old March 13th, 2010, 07:32 PM
I rarely repack the bearings. If the grease loooks good (I use synthetic) and not water contaminated, I jsut put some more grease on it and let it go.
Old March 13th, 2010, 08:23 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Just don't forget that you're going to need both a hub tool to get the hub off, as well as 12pt sockets (can't remember the size... 13mm? 14mm?) to get the rotor off the hub.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 13th, 2010, 08:32 PM
61rover's Avatar
61rover
John Crouse
The bearings are Timken Set 37. Usually not hard to find.
Old March 13th, 2010, 09:24 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
Thanks all for the details on this. If I decide not to tackle it myself what should I expect in labor costs/time for rotors, pads, bearings/seals all for front and back?
Old March 13th, 2010, 10:05 PM
4ish hours
Old March 15th, 2010, 01:12 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Timken SET37, SKF BR37 or FAG KIT38, about $13 locally, 2 per hub.
Seal is RTC3511
You can clean and inspect the bearings and only replace as needed.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Inner hub seal seating depth KevinNY Defender Technical Discussions 32 September 12th, 2009 02:05 AM
series front hub seal airbornrover Series Technical Discussions 1 November 12th, 2008 08:48 AM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
