Front Recovery Points - Defender Source
Old April 12th, 2004, 12:51 AM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Front Bumper Shackle
I couldnt find it using the "excellent" search feature of the BB ()... I was trying to find the front bumper shackle that mounts with a single bolt and pivots on that bolt. I think CVC has one.
I know they're inherently not as strong as a four-bolt or welded install, but if you put a backer plate behind it, is that "strong enough" for most applications? I mean I'm not hanging the truck from under a helicopter or anything...
Old April 12th, 2004, 10:35 AM
Troys
Troy Smith
1995 D90 SW
Ken;
Are you looking for the type on my front bumper? If so they are manufacturered by Actek. I forget who I purchased mine from but I can find out. They make them in several different materials. I have a catalog with all their products.
Troy
Old April 12th, 2004, 11:56 AM
Ken,
I just sent you mail.......Dave
Old April 12th, 2004, 12:00 PM
loykd's Avatar
loykd
Ken Loy
The Actek site (www.actekmfg.com) shows one made in Aircraft Quality 4140 and Stainless. For a 5/8" bolt, 4140 has a 4000# load rating and SS has a 2000# load rating.
What would you think to be the appropriate requirement for a recovery point?
Old April 12th, 2004, 12:11 PM
Troys
Troy Smith
1995 D90 SW
Ken;
I considered the stainless versions myself. The cost was a bit unreasonable I thought. They make a few different finishes. I went with the standard black. If you do decide to go with the stainless I would get the 4140. The last thing you want is to be out winching and have the thing let go. Then you'll be wishing you had spent the extra coin. I will check and see what size I used as well. I will try and get to my shop tonight and find out for you.
Troy
Old April 12th, 2004, 12:14 PM
I think the jate rings are also an excellent alternative
Old April 12th, 2004, 12:36 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I have the military grade ones that I think you are talking about. I would be willing to sell them if anybody is interested. If so, let me know and I will put them in for sale with a picture.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 12th, 2004, 02:40 PM
Ken have you seen these ? they are rated at 3 tons.
Old April 12th, 2004, 03:48 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
If the vehicle weighs around 3,500lbs than I would think 2,000lbs is way to lite and 4,000lbs is pushing it also... I wouldn't want to be standing anywhere near a truck that was being pulled out with that lite of a recovery point. Aren't the warn shackles that fit in the hitch receiver about 8,000lbs????
Old April 12th, 2004, 04:22 PM
Ken If you are staying with actekmfg then I would suggest these as they are rated Higer with smaller bolts. I think the 8,000 or 10,000 should be good with a good backing plate.
Ken any Idea of the cost of those things? I was thinking of getting some of these .
Old April 12th, 2004, 06:46 PM
loykd's Avatar
loykd
Ken Loy
I suppose this ends up being an engineering question. It certainly seems to simple-minded me that four (albeit smaller) bolts for the SMB would be much stronger than the single (larger) bolt for the shackle I showed. And if you're talking about welded on shackle mounts as Rockware does... well, you're well out of my league there. Would one consider a welded bracket to be that much stronger than a bolted bracket?
And more importantly, how much is enough?
As for you Mike, you always seem to find 'em bigger and better. That's a beefy mount! Put one of those jaws on the front of your truck and you'll be ready to pull down a barn! . Kidding aside, the weakest point would be the same as the SMBs, at the 4 mounting bolts. Next of course would be where the bumper attaches to the frame. I'm not so sure I'd like to see you replay the scene in American Graffiti where the cop car drives out of the lot and leaves the axle behind.
Old April 12th, 2004, 07:41 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
Ken, is this what you're looking for?
Swivel Eye
Glenn
Old April 12th, 2004, 09:59 PM
loykd's Avatar
loykd
Ken Loy
Glenn, THAT'S what I remember us talking about! Thanks. Now I'm curious on the tensile strength of that 18mm high grade anodized steel bolt...
Old April 13th, 2004, 01:18 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Ken, it's rated at 15 ton.
John C.
Old April 13th, 2004, 01:23 PM
Just poking around the actekmfg website and I found out there stuff is rated 5 to1 so If it is rated for 2,000 lbs it is meant to handle 10,000 lbs.
Old April 13th, 2004, 01:36 PM
loykd's Avatar
loykd
Ken Loy
Giampaulo, where do you get that number? I was looking at bolt specs and nothing looked that strong. Certainly not doubting you, just trying to understand.
Are the Scorpion swivels the same as the ones on the actek site? anyone know?
Old April 13th, 2004, 03:08 PM
JohnC
Correction: 50 ton (UK) is the equivalent to 33,600 lbs (US). Sorry for the mixup. I got the information directly from Scorpion.
As far as I know they are not the same as Actek.
John C.
Old April 13th, 2004, 04:01 PM
1 ton UK = 2204.62 lbs so 50 tons UK = 110,231 lbs. THat does not sound right.
Old April 13th, 2004, 04:32 PM
JohnC
You are right Michael, for some reason I said it was 50 tons when it is only 15 tons. Sorry about that.
Sorry guys!
John C.
Old April 13th, 2004, 04:42 PM
AHHH, thats makes sence. I bet it is not 5x rated like the Acteks.
cover
Front recovery points (long) GaryBaxter Defender Technical Discussions 20 August 19th, 2007 08:00 AM
Equipe Swivel Recovery Points RedRhinoProducts For Sale - Parts 7 March 17th, 2006 06:01 PM
Recovery points on LR winch bumper? jam90 Defender Technical Discussions 18 October 18th, 2005 08:06 AM
Help, what kind of front recovery points UpnOver Defender Technical Discussions 7 July 5th, 2005 12:40 PM
